Oils question
howl
Oils question
Fri Mar 28, 2008 6:30 am » Post: #1 » Download Post
Hi all . I was wondering if there was a list of recomended oils as I want to change my gearbox oil on my 18 (wet clutch) . It had Silkalene light gear oil last time , is this what you use or should I just stick in Castrol GTS ? Cheers
cgallant
2001 Honda RS250
Fri Mar 28, 2008 12:38 pm » Post: #2 » Download Post
Silkolene, Motul, Castrol? They are all excellent products. Get a good lite weight gear oil from a good manufacturer and you should be good to go.
Charles Gallant
howl
Sat Mar 29, 2008 6:24 am » Post: #3 » Download Post
Thank you for your reply ,only asking as my wet clutch is only just not slipping when warmed up . The plates are the correct thickness and the std springs are the correct length. I now have some EBC HD springs to put in as I have some new Jolly Moto pipes to put on and get it dynoed and don't want it to slip with an increase of power just because I put the wrong oil in .
