Rebuilt questions
NSR-LOVER
Rebuilt questions
Sat Feb 23, 2008 9:47 pm » Post: #1 » Download Post
Hi mates!
Well spring is coming soon and i've got to hurry and fix my seizured 21. Twisted Evil
Found 2 good barrels(H\C AND L\A) and now searching for the rest needed for the rebuilt.I have the heads kv3HRR and kv3LFR so i'm ok with these?
I was thinking to measure the exact diameter of the barells with a
micrometer and then choose the best piston to fit from the 3 stock's or do
you think it is too much and i should go with the standard information:
'A' Cylinder - 'B' Piston
'B' Cylinder - 'No mark' Piston
'C' Cylinder - 'D' Piston
Sat Feb 23, 2008 10:28 pm » Post: #2 » Download Post
Are you going racing? If the answer is yes, are you that competitive that it makes a difference? If so, measure the barrels and choose the piston best suited to the barrel and race conditions.
If the answer is no to either of the above, then go by the A|B, B|#, C|D Honda guidelines.
NSR-LOVER
Sat Feb 23, 2008 10:39 pm » Post: #3 » Download Post
No its not for racing just a very carefull rebuilt.
So i need one B and one D...
The mark on the piston is on the top in the middle?Ive seen a few but no mark maybe it was the 'no mark' ones.
Rings,pins etc are all the same?
Sun Feb 24, 2008 12:12 am » Post: #4 » Download Post
Use MC28 part numbers. Rings, pins, clips are all the same part numbers.
NSR-LOVER
Mon Feb 25, 2008 7:27 pm » Post: #5 » Download Post
Sorry but i have no idea with the part numbers...
Where can i find?
richie
Mon Feb 25, 2008 7:34 pm » Post: #6 » Download Post
you will find them in the parts manual on this site.
cheers
richie
NSR-LOVER
Mon Feb 25, 2008 7:38 pm » Post: #7 » Download Post
I searched for rings but cant find.
Mon Feb 25, 2008 8:12 pm » Post: #8 » Download Post
Look under "Crankshaft E16".
NSR-LOVER
Mon Feb 25, 2008 8:50 pm » Post: #9 » Download Post
Found them, thanks and sorry for the hard time...
I will try to source them but it is hard to found them(the exact pistons B\D) here in greece.
