Basically its current state is the heads and cylinders have been removed. but few thingss i noticed when i striped it was the cable to the valve on the cylinder i assume is the power valve, correct me i im wrong. thats snaped and so has the thread. the cylinders are crack between the outlet.
basically im wanting to get it back on the road and was thinking of the tyga 300 kit as it has everything i need just need opinions on it if its worth doing or just restre it back to its 250 standard self.
or if you have any other ideas would be greatly appricated cheers peeps.
