MC21 key number
mick
MC21 key number
Mon Jan 28, 2008 5:45 pm » Post: #1 » Download Post
Anyone know where the key number is on a 21. And even if I can find it without wrecking anything can a key be cut from a number?
Mon Jan 28, 2008 6:39 pm » Post: #2 » Download Post
Can you not take the ignition barrel off and take it to a locksmith?
One bolt is a T8 Torx I think, and the other is a security "sheer" bolt that needs to be tapped out with with a punch (same way the heathens tap off swingarm lock-rings!). The sheer bolt won't be too tight though.
mick
Mon Jan 28, 2008 9:14 pm » Post: #3 » Download Post
Andy wrote:(same way the heathens tap off swingarm lock-rings!)
Rolling Eyes Laughing
If I do take the barell to a locksmith how is he or she (PC and all that) going to be able to cut a key for it unless I stumble across the keymaker from the Matrix. Laughing
Tue Jan 29, 2008 12:12 am » Post: #4 » Download Post
A good locksmith is The Keymaker... The Keymaker is all locksmiths! Very Happy
Do you think The Matrix is just a movie? Laughing
A good smith will be able to make a key from the barrel... whether he wants to, or thinks it is economically viable, is a different matter though.
SLF-951
Tue Jan 29, 2008 12:21 am » Post: #5 » Download Post
I once lost my only key for a bike. After several calls I found a couple of locksmiths that claimed they would be able to make a new one from the ignition. I was quoted 75 if I brought it to them and 125 if they came out. So, I took it out and as I made my way to lock the door before I left.........There's the damn key hiding in the grass !!!!
Kinda pricey, but if you need it........
MC21
04 NSR50R
93 CBR F2
98 CBR F3 track bike
95 VFR750
89 FL400R Pilot
90 FZR 4/600
maximum
Tue Jan 29, 2008 5:12 am » Post: #6 » Download Post
Is that $75 ?Send your keys to Thailand and we can cut them for 75 Thai Baht around $2.50.
My Bikes;
TZ250K
TZR250 3XV Sugo kitted track
TZR250 3XV modified road
NSR250R MC21 Rothmans
NSR250R MC18 Modified road
NS400R
Dio 80cc big bore with 26mm flatslide (wicked)
900RR Fireblade
SLF-951
Tue Jan 29, 2008 5:19 am » Post: #7 » Download Post
Was 75 US dollars...... Like I said, it's pricey, but if in need....... Only choice. Point is, keys can be made by a locksmith from the ignition.
MC21
04 NSR50R
93 CBR F2
95 VFR750
89 FL400R Pilot
90 FZR 4/600
maximum
Tue Jan 29, 2008 5:36 am » Post: #8 » Download Post
Absolutely.Send me your barrels
My Bikes;
TZ250K
NS400R
900RR Fireblade
mick
Tue Jan 29, 2008 9:20 am » Post: #9 » Download Post
How much would it cost to get one cut from the barrel. Taking into cosideration that either the barrel or key where pretty worn in the 1st place.
It may be cheaper and easier to find another lockset.
Tue Jan 29, 2008 9:25 am » Post: #10 » Download Post
I'd try an get a key cut Mick. Trying to get into the tank to replace the filler cap is a right swine. I've had to do it twice and both times I've managed to bleed all over the thing.
Getting the ign barrel off is easy, just take the yoke off. That is unless you've locked the steering and then lost the keys. I've done that too!
Chester362
Tue Jan 29, 2008 11:14 am » Post: #11 » Download Post
On the spare barrel I got with an old bike, (with no key also). There`s a number stamped on the face where the steering lock bolt pokes out.
M & P do replacement ignition barrels too. You`d have to find a model which shares the same barrel as the NSR. Should be about £35 for one from M & P.
I`ve had a locksmith cut me a key from a lock barrel before. They just need to know which is the correct blank for the lock. Depends on who you go to. Some will attempt it, others won`t.
Tue Jan 29, 2008 3:19 pm » Post: #12 » Download Post
I just leave the key in mine all the time! Embarassed Wouldn't be surprised if it was seized in the lock by now! Laughing
mick
Tue Jan 29, 2008 7:41 pm » Post: #13 » Download Post
Andy wrote:I just leave the key in mine all the time! Embarassed Wouldn't be surprised if it was seized in the lock by now! Laughing
Thats fine if your near the bike all the time. Laughing
Mine is at the mother inlaws in a garage that is left open all the time down a quiet country lane.
Tue Jan 29, 2008 8:00 pm » Post: #14 » Download Post
It's on my Dad's drive, under a cover... about 12 miles away. Confused
Wed Jan 30, 2008 2:46 am » Post: #15 » Download Post
A good locksmith probably knows more than they're gonna let on.
I've taken an ignition barrel, tank filler and set lock (all different) to the key man, and an hour later picked up the "one for all and all for one" key. Job done.
