rising plate for the rear shock linkage
gregjet
Mon Nov 05, 2007 8:33 am » Post: #1 » Download Post
http://tech.nsr-world.com/nsr/mc18/f3-rear-suspension/
Can anyone tell me which hole is which in the diagram.
I have an 18 and the F was at the front of the plate when I got it ( could have been stuffed up of course.
If the virtual hole position is supposed to be the original NONE of the dimensions is the same as my linkage plate.
I be confused!
fenton
1990 Honda NSR250 MC21
Re: rising plate for the rear shock linkage
Mon Nov 05, 2007 12:45 pm » Post: #2 » Download Post
gregjet wrote:If the virtual hole position is supposed to be the original NONE of the dimensions is the same as my linkage plate.
I be confused!
because that link in your post is for the f3 plate !
howl
Mon Nov 05, 2007 5:19 pm » Post: #3 » Download Post
Hi I made the plate as per the drawing ,and when you come to fit it , it will only go on one way and is a great improvement. It does jack up the back a fair bit so be sure to turn the petrol off as the bike leans over a lot on side stand so the floats might stick somtimes.
gregjet
Tue Nov 06, 2007 10:16 am » Post: #4 » Download Post
I made up a dummy and it will fit in all three positions ( that is rotating it around to each hole. I have made linkage plates to raise rear ends before and I know how much work went into getting the dimensions, but I really need to know which hole is for which item.
As the diagram appears the shock would be the top right; the swingarm lug, the left and the bottom is the frame linkage. But this would make the "F" mark on the top. I don't know if this actually matters or not.
The bike is for track racing only on a VERY tight track, so the steep forks and more ground clearance is exactly what I want. Won't ever have a side stand
howl
Tue Nov 06, 2007 4:51 pm » Post: #5 » Download Post
Hi I have been out to have a look and the 70mm centre holes are at the rear with the sharpest angle at the top ,if you see what I mean. It will be great on the track and cheap as chips if you've got a couple of bits of alu kicking around.I did mine with a jigsaw and a file ,drilling both bits at once to keep the holes lined up. The chain does touch the exhaust but it's fine once your sitting on it. I hope this helps.
gregjet
Wed Nov 07, 2007 8:29 am » Post: #6 » Download Post
Thanks, I'll give it a try. Even if I can't get the motor going properly I might make it into a supermono or maybe the new rules for GP125 in Australia next year which may allow 250 4stroke water cooled singles . Stick a CRF250X motor in it.
rgvkiwi
Wed Nov 07, 2007 8:34 am » Post: #7 » Download Post
Did you see at Philip Island the RS125 with CRF250x motor in built by Moriwaki on display?
I took some photos of it if you didn't.
Mark
gregjet
Wed Nov 07, 2007 10:14 am » Post: #8 » Download Post
It is in the latest AMCN with a short piece on the proposed changes. Would like to get the NSR motor going because it is quite simply a truly beautiful peice of engineering but if not... either a bike single for supermono or a single 250 for GP125.
