Rim width???
jkolewski
Rim width???
Sun Oct 14, 2007 9:53 pm » Post: #1 » Download Post
Topic says it. Just wondering how wide sp magtek's are? I know there not 3.75 and 5.5. I'm guessing 3 and 4.25 or 4.5.
1995 A kit TZ 250
1994 Rothmans NSR 300sp SOLD
Sun Oct 14, 2007 10:53 pm » Post: #2 » Download Post
Yep, they are 3" front and 4.5" rear
mixalisen
Mon Oct 15, 2007 10:43 am » Post: #3 » Download Post
Is there enough clearance to install a wider rim…? For example 5’’…
Mon Oct 15, 2007 10:45 am » Post: #4 » Download Post
You can run up to 5.25" on the rear if you want and 3.5" on the front.
mixalisen
Mon Oct 15, 2007 8:36 pm » Post: #5 » Download Post
Mmmm...!!! That is very interesting... Does anyone have made this modification...? From which bikes can i fit a wider rear rim to my mc21...?
Mon Oct 15, 2007 8:56 pm » Post: #6 » Download Post
MC21 HRC F3 rear wheel fits right in as long as you also use the HRC rear caliper, disk and sprocket carrier.
Not much else will fit right in without mod's though.
You could look at RS Dymags etc but all will require new spacers/disks/calipers etc.
Mon Oct 15, 2007 9:29 pm » Post: #7 » Download Post
Maxim fitted a TZ250 rear to his MC21. Tyga supplied it, but not too sure if it was a straight bolt up.
Wed Oct 17, 2007 11:15 am » Post: #8 » Download Post
RS250 5.25" rear is the easiest to fit. As StephenRC45 says you do need all the HRC gubbins to go with it, but than can be sourced. Well some of it can. Or fabricated.
I've got TZ marvics in my bike. Rear's 5.25". It was an easy fit, just so long as you have a machine shop at your disposal Wink
Front 3.5" rims are common on NC30/35 and bolt straight in. They're not Magtek's though. If you want magnesium wheels you'll need an RS front. Pretty much plug 'n' play, but will need a front spacer change.
If you have the knowledge, the time and the tools you can get anything to fit within the boundries of common sense.
Wed Oct 17, 2007 12:04 pm » Post: #9 » Download Post
Everythings quite easy if you have a lathe and a Mill. I dont know how people manage to build bikes without them.
Its one of those thinsg once you have it you use all the time. Well worth the money.
maxim
Wed Oct 17, 2007 1:00 pm » Post: #10 » Download Post
Mine is a 5.25 RS wheel. Nothing needed changing apart from putting a different spacer in, and using RS250 sprokets... I ordered an AFAM one through Steve Patrikson. Still using the orginal MC21 caliper and bracket, and original MC21 disc, which is a direct bolt on! Good luck finding one though!!
Wed Oct 17, 2007 1:10 pm » Post: #11 » Download Post
Now I thought all RS 5.25 magteks where a 4 bolt disk not the NSR 3 bolt job. Learn something new every day Very Happy
Thu Oct 18, 2007 2:12 am » Post: #12 » Download Post
When I've made my first £million (which ain't gonna be this week!), my workshop will be fully fitted with CNC machining centre and lathe, and one of them there laser cutters. I'll keep my little lathe though 'cos it's blooming handy for turning little bushes up Very Happy
Then the world will be mine Cool
That's unless Steve steals it first Evil or Very Mad
Thu Oct 18, 2007 7:15 am » Post: #13 » Download Post
Would I steal the world from you Matt Very Happy
maxim
Thu Oct 18, 2007 8:27 am » Post: #14 » Download Post
StephenRC45 wrote:Now I thought all RS 5.25 magteks where a 4 bolt disk not the NSR 3 bolt job. Learn something new every day Very Happy
It's not a Magtek but a Technomagnesio. I think Matt said it was an F3 wheel so maybe that's why it's a direct bolt on?? Matt?
Thu Oct 18, 2007 8:31 am » Post: #15 » Download Post
I think up untill '93 all HRC wheels were Magteks (made by Enki), from 94 on they started to use Marc's
The 5.25 F3 wheel in the '91-92 manual is a Magtek for sure.
Still as long as it fits hey?
