Cracked chassis
80XAR
Cracked chassis
Sun Jul 08, 2007 12:05 pm » Post: #1 » Download Post
I have found a crack in my chassis ? WTF. On the kickstart sidewhere the box section is welded to the bottom section. Just near the rear shock canister. Right down the middle of the weld !! Its only very thin. About 3" long.
Anyone else ever seen this ? I ve organised to have it welded, but i have never seen this before.
Sun Jul 08, 2007 5:38 pm » Post: #2 » Download Post
Never heard of this before. The quality of build during the NSR's run was Honda at it's best. I would advise you have the whole frame checked over, as it sounds like it may have been in a major shunt.
Better to be safe than sorry.
Steve C
Sun Jul 08, 2007 6:58 pm » Post: #3 » Download Post
I also had a crack on my mc-21 on the other side. You can see a picture of it here. http://www.flickr.com/photos/9744934@N04/734552587/in/set-72157600676925001/
80XAR
Tue Jul 10, 2007 9:45 am » Post: #4 » Download Post
It was involved in a minor road shunt (hence why i am rebuilding it)
I took it to a fella over here in Brisbane called Dave Pellett, who straightens and fixes alot of race bikes that get tossed. If there was anything cracked or not right he would of found it.
80XAR
Tue Jul 10, 2007 9:58 am » Post: #5 » Download Post
Try this link. Sorry about quality, taken from my phone.
p0lariso
Shocked
Tue Jul 10, 2007 1:04 pm » Post: #6 » Download Post
Im amazed to see that weld cracked like that.. Id guess it was a bad weld, not enough filler rod or penetration. Curious how many miles on that frame as aluminum stresses over time.
80XAR
Thu Jul 12, 2007 10:10 am » Post: #7 » Download Post
This chassis has 32000 km on it (about 19000 miles i guess)
Engine pulled down at 32000km. Mech recons engine looked like it had done barley 8000, checked all clearences, replaced all seals and gskts, set of rings and hoan. Only done 200 ks since. Ironing out all these gremlins Evil or Very Mad
p0lariso
Thu Jul 12, 2007 2:02 pm » Post: #8 » Download Post
Could have had a 300 pounder riding it then Very Happy Is the suspension and seat all blown out Very Happy
alannsr250
    Send private message View user's profile Send e-mail Visit poster's website MSN Messenger
Thu Jul 12, 2007 10:27 pm » Post: #9 » Download Post
my f reg nsr 125f had a big crack in the alcast frame between the top and bottom engine mounts.
drill a hole either end of the crack and it wont get any worse then grind the weld off wer the crack is making sure it doesent get hot. them send it to somone to be welded there shud be plent of people around, i drill on end on my crack and bolted two tread plate cover one on the crack side and on on the other lol so i could mot it,
Honda nc23 CBR400 AERO 1986, 1990 honda NC23 Tri-Arm, 1987VFR400 NC24 Rothmans Rep, NSR250 MC16 1987, CL250s 1983. Moto guzzi zigolo 110cc 1958. Fantic 50cc 1972. Suzuki Cobra Race bike 500cc 2t 1975 , GP125 1975. Triumph T110 1954. BSA Thunderbird 1955. Ariel VB 600 1952, 1990 MuZ 125 etz.
80XAR
Sun Jul 15, 2007 9:46 am » Post: #10 » Download Post
Ive already lined us a fella to repair it. Very handy with the ole' welder, so he'll do a top job on it for me
HRC 6968
Crack
Mon Jul 16, 2007 8:02 am » Post: #11 » Download Post
Did you try and race on of those Air force planes out at amberley and got shot you down. Have to meet up in a september october, for a ride, Glorious/nebo or something, you ever ridden with Tommy Ruxton or the guy from Bluedog Landscaping - Seen his ute and trailer the other day, Quite flash
HRC Is Getting Expensive
Its' like the AIR is crappy at Ground level.
80XAR
Mon Jul 16, 2007 1:01 pm » Post: #12 » Download Post
Nah. Been off the road for about 3 years. Still ironing out gremlins, like cracked chassis. Should be going reliably buy sept. Let you know
I work with a guy with a CRB1000 who was up that way on sunday just gone. Said there was lots of bikers out. He may know them. Hes always at Darington and QLD raceway doing track days.
I dont know if im real keen for Glorious. In the WRX, yep. NSR, might get some more k's under the belt, and some new tyres (read : old, hard not confidence inspiring). My balls are much larger in the rex than the NSR at this stage Laughing Definatly car guy before im bike guy.
80XAR
Mon Jul 23, 2007 10:15 am » Post: #13 » Download Post
Speaking to a guy today, who said to be carefull if welding the chassis as some road bikes have some sort of foam in the hollow sections of the chassis, and that it is flamable.
I dont think an NSR would,as it sounds like unnecisary weight. Anyone know for sure ?
Canuck13
Tue Jul 24, 2007 3:14 am » Post: #14 » Download Post
other issue in oz is the recent requirement (vic anyway) for all frame welding to be done by a certified welder and then to be inspected by a engineer.
HRC 6968
learning myself
Tue Jul 24, 2007 9:44 am » Post: #15 » Download Post
cool as, went over on friday nite myself with a mate in a vp 6, alot more bumpy than it was 8 years ago, he liked it that much that he went home a different way.
Rebuilding my bike as well, brought another pair of Carbs, HRC Race Loom and box, flywheel, Clutch inner, Wheel bearings, Piston kit, Twin Uni Filters 52mm and 55mm , Dry clutch Setup, Its using a Michelin Pilot powers rear and Bridgestone front.
looking at annodising/powdercoating the frame. and aiming for Majority of F3 and HRC gear., Guy at works Uncle is WAYNE GARDNER, Rather interesting.
