big problem?
ilovemynsr150sp
big problem?
Mon Jun 04, 2007 12:38 pm » Post: #1 » Download Post
hey everyone, this is my first post so please be gentle on me Razz i have a small problem which i cant figure out so i thought i should post it up here... io ahve a honda nsr 150 sp...everything started with my left headlight not working, so i got it out and checked it, it looked fine so i plugged it back in, turned ignition on but nothing happened...at first i thought i didnt put my key in far enough...so now my problem is that my whole bike has no juice left, even the neutral light doesnt work...(whole bike doesnt light up) i tried to explain as good as i could, what could be the problem, im sure it cant be the battery or the fuse, i checked the fuse and the battery is very new and my dad rode my bike today without any probs... could it be something to do with the ignition?? any thoughts on this would be very appreciated... thanks, stef
Ride: Honda nsr 150 sp
pbekkerh
Mon Jun 04, 2007 12:55 pm » Post: #2 » Download Post
You have to check the battery. Even a new battery can be discharged. Measure the voltage on the battery, if its ok then measure if there is any voltage on the lead , coming from the battery, on the keyswitch then, if there is any voltage on the lead leaving the keyswitch.
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
ilovemynsr150sp
Tue Jun 05, 2007 3:14 am » Post: #3 » Download Post
hey thanks for your reply, i just found the problem, i had a broken lead form my key switch which the prvious owner tried to fix himslef... thanks again
