Airbox or Filters?
Rabbit1445
Airbox or Filters?
Tue May 22, 2007 8:57 pm » Post: #1 » Download Post
I have an 92 MC21 SE. I am in the process of switching over from stock to a HRC derestrictor, HRC Jet Kit, Tyga High Flow Reed Kit, and Specially made Tommy Crawford RS250 Chambers. Im wondering if I should run a modified airbox lid or switch to individual filter?. If I switch to filters what would you guys recommend? K&N, Uni...???
92 NSR250 SE
91 Ducati 900ss
03 Buell XB9S
06 HD StreetRod
76 Yamaha RD400 (TZ Bodywork)
Custom Bobber
01 Yamaha WR250F
nsr250racer
Tue May 22, 2007 9:39 pm » Post: #2 » Download Post
If it is just for street riding, any pods would work...if for track, you may want to run open carbs setup(no filters) More air = more ponies.
FILOLI - Fight, Love, Live
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Wed May 23, 2007 1:26 am » Post: #3 » Download Post
In my opinion pod filters are probably not much better than running a modified airbox. If any beter at all.
I reckon the way to go is either open carbs, or mod the airbox. And by mod the airbox I mean seriously mod the airbox.
As stock the airbox is really two small chambers, but you want to chop the middle divider bit out so that you get one big airbox. Not so clever right down the bottom end of the scale, but bettertop end performance. You can run with a lid (and filter), but obviously the entry need modifying to allow maximum air but no more. Then chop the inlet rubbers down flush with the airbox and put a nice rad on them, then you get the best right through.
Wed May 23, 2007 9:00 am » Post: #4 » Download Post
nsr250racer wrote:If it is just for street riding, any pods would work...if for track, you may want to run open carbs setup(no filters) More air = more ponies.
Open (lidless) airbox compared with open carbs;
Better figures, better sound, feels faster but in fact is slower unless you believe you can keep the revs above 10800!
Modded (two * 1" holes) lid on the airbox feels like it makes no difference to top end go but seems to give a load more mid throttle, mid revs response.
