MC 28 Wiring Problem
georgetaylor208
Sat Feb 17, 2007 11:20 am » Post: #1 » Download Post
Hallo
The MC 28 i have came with an Air-Box that fits to the Under-Side of the Tank, close to this is some-sort of Valve with 3Pipe connections and 1 Electric, the Throttle has some-sort of Sensor or Pikup wich is wired into the Circuit, on the inside where the Cable fits is a small Aluminium-Plate,
inside the Head-Stock is a Black-Box No Make or Number it measures
57X94X18 mm with a thick Rubber-Backinkg there is a Small-Red light
oposite end to the Wiring, when i Switch on the Warning-Light lights up,
can anybody tell me How to Wre everything up Correctly, and is the Black-Box a Delimiter, the Wiring-Harness is HRC but i would like to fit the Stndard one.
Thanks
George
