Fuel/Oil Mixture
czsphl
Fuel/Oil Mixture
Wed Feb 07, 2007 1:22 am » Post: #1 » Download Post
Guys,
I just want to know what is the right mixture for fuel and oil in case the oil pump fails.. I have stock engine, stock air-box and jettings. is it 30:1, 20:1? I really have no Idea.. and maybe this is a stupid question, what is the convertion of that 20:1 or 30:1? is it 20 liters of fuel per 1 liter of oil?
Thanks guys..
scottvor
    Send private message View user's profile Send e-mail AIM Address
Wed Feb 07, 2007 4:10 am » Post: #2 » Download Post
Yes, you are comparing volume of fuel to volume of oil. 30L of fuel will need 1L of oil. 30:1 is a good ratio for the NSR250.
czsphl
Wed Feb 07, 2007 5:51 am » Post: #3 » Download Post
Thanks mate..
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Thu Feb 08, 2007 9:15 am » Post: #4 » Download Post
Different oil manufacturers specify different oil ratios, but 30:1 with a synthetic is a good start for a road racer.
My oils of choice are Castrol A747, Shell Advance Racing or Elf HTX976. I'm running Elf in my 300 now at 30:1, and I was also using it in the CR500SM @40:1. Good as gold and smells lovely too.
The different ratios are because the 300 revs hard (up to 13,000), whereas the 500 is a lazy pig in the rpm department. The 500 also spends less time flat out.
Remember that if you're pre-mixing, and you intend to try different ratios this will affect your jetting. If you go from 40:1 to 20:1 it sounds like a safe bet against seizure. However, if you haven't jetted for the new ratio then you've actually leaned the air/fuel mixture because you've displaced the fuel with oil, but the same amount of air. So you could actually seize.
HRC recommend 30:1 (A747 or HTX976) for their GP bikes. Do it!
