power
PhiLLaY
power
Sat Jan 13, 2007 8:04 am » Post: #1 » Download Post
need more power for mc28
thanks in advance
phil
Sat Jan 13, 2007 8:23 am » Post: #2 » Download Post
The '28 is by far the hardest NSR to get power from;
The exhausts have restrictors in the headers (and weigh a ton), either replace the chambers (Tyga are good and cheap) or take the pipes off and spend some time with a dremel removing them.
Like all NSR's the airbox is restrictive, 4*1" holes in the lid seems to works best.
The ignition is retarded, a vaguely effective workaround is to use the flywheel from an MC21 but you're not going to get really good power (anything over 60bhp) out of a '28 on the standard card, the HRC card is the way forward.
As with all mods, check the jetting
PhiLLaY
Mon Jan 15, 2007 6:54 am » Post: #3 » Download Post
thanks for the reply, im not after world record breaking power but something to give me a bit more G's from 0-140km.
Would i feel anything if i changed the end cans, drill some holes in the airbox?
Stock and really slow MC28SE Repsol Rep... =(
Mon Jan 15, 2007 12:10 pm » Post: #4 » Download Post
Cans do very little, removing the restriction in the pipes has to be done and is worth plenty of ponies. See here for the difference race pipes alone make to an MC28.
The airbox is a restriction but the '28 has far bigger problems, mainly the pipes and ignition.
Tyga did a bit of a '28 on a std card here
Mon Jan 15, 2007 12:38 pm » Post: #5 » Download Post
While not an MC28 here is some graphs of an MC18.
Purple trace is stock pipes and cans
Blue trace is stock pipes with swarbrick cans
A small increase all the way up, maybe not really worth it but every increase is a step forwards.
PhiLLaY
Mon Jan 15, 2007 12:43 pm » Post: #6 » Download Post
so it looks like i gotta take off the pipe and start the dremel. If i take the pipes off would the gaskets need to be replaced. Should i clean out the cans before buying new cans its probably filled with crap
Tue Jan 16, 2007 12:00 am » Post: #7 » Download Post
MC28 cans are more restrictive than the earlier models too. For a cheap fix, slip on some MC21 cans... they aren't the perfect answer, but they are both lighter and less restrictive.
Better still, buy some MFactoryWest cans from the Marketplace! Wink
j911brick
Tue Jan 16, 2007 1:20 am » Post: #8 » Download Post
Andy wrote:MC28 cans are more restrictive than the earlier models too. For a cheap fix, slip on some MC21 cans... they aren't the perfect answer, but they are both lighter and less restrictive.
Are those cans a direct bolt-on to stock chambers?
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
PhiLLaY
Tue Jan 16, 2007 12:07 pm » Post: #9 » Download Post
hi guys,
jetting my bike... any competent bike mech with a dyno can perform this?
Tue Jan 16, 2007 1:45 pm » Post: #10 » Download Post
Probably not Wink
Tue Jan 16, 2007 1:53 pm » Post: #11 » Download Post
We cant even find one in the UK lol
Tue Jan 16, 2007 9:15 pm » Post: #12 » Download Post
The bolt pattern is the same, but on some pipes (MC28 for example) the "stub" needs to be cut back flush with the flange to allow the cans to pull up nice and snug.
