PGM3 installed where this plugs go?
demetris74
Wed Jan 03, 2007 11:27 am » Post: #1 » Download Post
Guys Happy new year
I have a small problem hope you can help me.
i replaced the PGM2 loom with PGM3 on my MC21. I cant seem to find where to connect 2 connectors located on a bracket mounted on the undertray. is one red and one white plug. i think they connect on 2 connectors located next to the shock and they cant reach there, is there any extension that goes there?
James
fenton
1990 Honda NSR250 MC21
Wed Jan 03, 2007 12:13 pm » Post: #2 » Download Post
it will be one of these two places
demetris74
Wed Jan 03, 2007 1:56 pm » Post: #3 » Download Post
Is the 2 plugs in the center of the undertray, therefore not the relay one.
i assmue are the GPS? but how come and they dont reach the other side of the plugs?
James
fenton
Wed Jan 03, 2007 2:41 pm » Post: #4 » Download Post
no the gps plug is on the side just down from the relay there should be a gray gps plug and a bullet connector there in the center of the tray there should be a red plug and a white plug that go onto the bracket that should be there
demetris74
Wed Jan 03, 2007 3:18 pm » Post: #5 » Download Post
Yes there are 2 plugs there red and white wich i find their other end at the magnetor area but they dont reach at that point where they should be pluged is that the distributor plugs?
do i need any extension to reach at the distributor area?
James
fenton
Wed Jan 03, 2007 3:27 pm » Post: #6 » Download Post
are you using the same pick-ups and stator of the mc18 ? as the wires are shorter as they mount at the side near the regulater. am not even sure the plus are the same
demetris74
Wed Jan 03, 2007 4:35 pm » Post: #7 » Download Post
Fendon i think you are right
they've must installed an mc18 magnetor and yes the plugs are defferent from mc21. Is it easy job to replace to mc21? is there any defference on power, cause if is not i will put back the mc18 loom but i have to sucrifice GPS and PGM3 what you think.
James
fenton
Wed Jan 03, 2007 4:57 pm » Post: #8 » Download Post
its very simple to put it back to 21 spec if you have the bits to do the job just take of the flywheel cover and the flywheel and it will be a 10 min job mate
demetris74
Wed Jan 03, 2007 5:04 pm » Post: #9 » Download Post
Thanks man
I will need also he distributor contacts right? do i need to adjust it or just remove the MC18 one and put the MC21 on place?
James
fenton
Wed Jan 03, 2007 5:09 pm » Post: #10 » Download Post
just change them over to 21 parts mate
