my rc valve got problem
poorguy
Guest
Thu Nov 04, 2004 3:53 pm » Post: #1 » Download Post
Hi everybody
my rc valve is work not normal,before i start the engine the rc valve is closed,it's ok but when the engine started the rc valve is move to full open
then close and full open again,then it always full open
why??????
anybody HELP ME!!!!!!
sorry about my poor english
Thu Nov 04, 2004 4:43 pm » Post: #2 » Download Post
The RC Valve acts "strangely" in neutral. It's only when the bike is in gear, and varying throttle openings are used (and varying rev's), that it seems to work "as it should"!
It's often normal to see the Valves "twitching" a little on idle. They will open up fully until about 1800-2000rpm in neutral, then close, then as the revs drop a little they will open again, and keep repeating this cycle. This can be a real pain when setting the idle speed too if the carbs are not set up properly!
If you can get the bike on a dyno, you should be able to see the system working properly. Alternatively, start the motor with the bike on a workstand and run the motor up through the 'box to cheeck all is well.
It is strongly advised that you roll the bike up against a wall and secure the front brake when you do this!
poorguy
Guest
how to check the rc valve
Thu Nov 04, 2004 5:21 pm » Post: #3 » Download Post
thanks for your reply Andy
so check the rc valve on engine idle and neutral is not complete correct
please tell me the how to check the rc valve and it open timing
i hope my mc18 can run normally
thanks
poorguy
Guest
Thu Nov 04, 2004 5:24 pm » Post: #4 » Download Post
thanks
