So i lost my key, what to do?
nsr250eeeee
Sat Nov 11, 2006 5:29 am » Post: #1 » Download Post
Cant find the key to my mc21 anywhere!
Is it possible to get a replacement? What are my options?
Sat Nov 11, 2006 10:38 am » Post: #2 » Download Post
Hmmm. Try taking the frame number to your Honda dealer?
Jump in your time machine and go back to when you did have it, and get a spare cut?
Sun Nov 12, 2006 9:21 pm » Post: #3 » Download Post
F3 ignition?! Wink You only need a kill-switch then!!
Seriously though, Dave's is the best option really, or scan eBay for an MC21 ignition barrel and key.
I belive the blank is similar to some cars, so maybe if you take the ignition barrel off and into a good locksmith, they may be able to make a key for you.
You'll need a T6 Torx bit to remove one of the bolts securing the barrel... unless it's already been off once for some reason!
nsr250eeeee
Mon Nov 13, 2006 3:41 am » Post: #4 » Download Post
Do nsr's have a key code somewhere on the frame?
Mon Nov 13, 2006 7:41 am » Post: #5 » Download Post
I'd doubt it, when the frame is made nothing as far in advance as the key barrel will even be decided.
Honda may or may not have records all you can do is ask.
But Honda bike blanks are available so a locksmith should be able to sort it out.
Mon Nov 13, 2006 1:05 pm » Post: #6 » Download Post
I just nip down to the old woman by the side of the road. She peers into the lock with an old dim torch, pulls out a file and hacks away at a blank. 5 minutes later I'm sorted. Thailand eh? Rolling Eyes
j911brick
Mon Nov 13, 2006 2:59 pm » Post: #7 » Download Post
I know I have checked a couple locall key shops and they didn't have a blank for the NSR. I'll bet Honda keeps the codes, but that also assumes the locks had never been changed before.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
Mon Nov 13, 2006 3:16 pm » Post: #8 » Download Post
I'm sure it's the same as a particular Toyota blank or something, but I honestly can't remember which. It was one of the guys Stateside that found out when he had the same problem.
You need to find a friendly auto locksmith who's prepared to spend 15 minutes with you to go through a range of blanks to see what matches the lock shape!
Personally I'd put a "wanted" advert in the Classifieds! I'm sure there is someone out there with an unwanted ignition lock and key.
Smokin'
Mon Nov 13, 2006 7:00 pm » Post: #9 » Download Post
Hey all you MC21 guys! In a nutshell, if nsr250eeeee is in the USA, Honda has no codes and most locksmiths have no codes. May be the same situation in other countries, too. The correct key blank is available from Honda for a couple bucks, #35121-MN9-611. Buy 2 and keep a spare. Code is marked on the barrel of the lock assy; Andy already gave removal instructions. With your new key blanks and with barrel in hand, try your local "real" locksmith, like the one Matt described. If you still can't get the keys cut then kindly pm me and we'll get this squared away right quick, eh. You do want to ride again, don't you?
Eric
Don
Mon Nov 13, 2006 8:50 pm » Post: #10 » Download Post
There's a guy on ebay that I got keys from and if you have the key code he can cut them for you. Look for keys4classicscom.
nsr250eeeee
Tue Nov 14, 2006 7:34 am » Post: #11 » Download Post
Thanks for the advice guys.
I havent given it a shot taking the ignition barrel off yet, but would it be made harder by the fact that the steering is locked?
Tue Nov 14, 2006 4:22 pm » Post: #12 » Download Post
No.
The only difference that will make is maybe access to one of the bolts, but you will be able to get in there once the top fairing and instrument stay are removed.
nsr250eeeee
Mon Nov 27, 2006 8:50 am » Post: #13 » Download Post
Well im totally stuffed now hehe.
I bought a torx set, got the 3 little torx screws out easy enough, but i ended up totally destroying one of the two larger torx screws either side of the barrel because it was in so tight! Now i have no way of turning it.
So I now have no key, no way of getting the lock barrel out, and no way of riding my nsr Sad
Any more options? Would this work to remove it
Long URL removed by Admin.
j911brick
Mon Nov 27, 2006 4:17 pm » Post: #14 » Download Post
Drill out the torx head. Or buy a new triple clamp and lock set.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
nsr250eeeee
Sat Dec 02, 2006 2:33 am » Post: #15 » Download Post
This is totally killing me, both the bolts are stuck fast and both the torx threads are ruined! Unless I spend $250AU getting a locksmith to come to my place, i'm screwed Crying or Very sad
