Seize end of straight
Fluffy Cat
Sun Oct 24, 2004 5:59 am » Post: #1 » Download Post
Just checking if i have this right.Long straight at Pukekohe race track slowing for hairpin back wheel locks bike seized,not to bad as it strarted next kick but on dismantling bad damage to piston and barrel.Anyway,the piston crown is undamaged and has black deposits the spark plug is a ten range and is medium brown no detonation marks to be seen.So my thinking the bike is full race with jha jet kit could it be off throttle fueling maybe bigger pilot jet in conjunction with up a size main jets.(it was the right/front cylinder)what do you guys think?.
Tue Oct 26, 2004 6:51 am » Post: #2 » Download Post
Was the major damage to the side of the piston facing the exhaust, and barrel damage around the exhaust ports?
Tue Oct 26, 2004 10:24 pm » Post: #3 » Download Post
Im guessing youre running premix? Its very common on dynos for a 2 stroke to seize on the shut off if youre not used to doing them.
Its also common for MX bikes to do it if going down hill on a closed throttle.
With an oil pump on the bike even if you shut off at high speed oil is still feed into the engine. Of course with premix if you shut off not only do you get no fuel, you dont get any oil either.
I think i can see where dave is going with his question tho.
Wed Oct 27, 2004 7:12 am » Post: #4 » Download Post
You can? Cool, I'm not sure I do... Shocked
Fluffy Cat
Seize
Wed Oct 27, 2004 8:24 am » Post: #5 » Download Post
Thanks for the replys,thought there would be none.The damage is all round,there are undamaged patches.The main damage was at the exhaust port,not on the bridge.It is only on one side and about 1cm wide most of the damage was superficial and could be polished out with some fine sand paper 1000# but there is a 1cm streak which is about 1/2mm deep which is not viable.The straight is long and i have the JHA carb kit in so bigger pilot jet which should help with off throttle cooling and lubrication.Checked the chart and found that the needle is recomended for the 4th clip,I was running on the second.So my fault guess it got lean on the straight!.Will go up a jet size on the front/200 should do itand go to 4th klip pos to be safe.There was no sign of pre det on the crown,it was quite black.The bike was going well and keeping up with many of the 4 strokes inc the sv 650s,Guess it will be a new barrel then.Still love the NSR and it loves new parts.Thanks,Bruno
Wed Oct 27, 2004 8:37 am » Post: #6 » Download Post
You won't need a new barrel if you get that one repaired. I don't know of any in NZ, but it may work out cheaper sending it to the UK / USA and having it repaired than buying new if there aren't any.
Search the web for Nicasil plating before you scrap it!
CBS
Wed Oct 27, 2004 5:32 pm » Post: #7 » Download Post
I have been racing 2 strokes for nearly 20 years and have never had a seizure on a closed throttle running pre mix.
Apex Leisure in the UK specialise in NSR`s.
Take a look at the following link which shows some info on piston diagnosois and replating of cylinders.
http://www.apexleisure.co.uk/enginetuning.htm
You can E-mail Jo if want any technical info.
I know she visited Pukekohe race track last year on holiday in NZ.
Jezza
Thu Oct 28, 2004 1:09 pm » Post: #8 » Download Post
Dave Ett wrote:You won't need a new barrel if you get that one repaired. I don't know of any in NZ, but it may work out cheaper sending it to the UK / USA and having it repaired than buying new if there aren't any.
What would be a ball park figure in USD or GBP for Nikasil plating?
In Australia, it can be done for about AU$600-AU$800 <- but don't hold me to it tho Shocked
Jerry Lai
NSR250 [MC21SP]
Thu Oct 28, 2004 3:31 pm » Post: #9 » Download Post
WHAT?
My last barrel - last year - was £103 including return postage!
Jezza
Sun Oct 31, 2004 11:36 pm » Post: #10 » Download Post
That figure was for two. Sorry for the confusion Embarassed Laughing
But it looks like it would be cheaper to send it to Apexleisure to get it done. And at least you'll know it's done properly.
Jerry Lai
NSR250 [MC21SP]
Mon Nov 01, 2004 7:52 am » Post: #11 » Download Post
As far as I know, Apex don't do the work in house, they farm it out to someone. You might save even more by going direct...
tightwad
Guest
replate
Tue Nov 02, 2004 5:55 pm » Post: #12 » Download Post
Dave Ett wrote:As far as I know, Apex don't do the work in house, they farm it out to someone. You might save even more by going direct...
Every tuner in the UK farms out the replating as it cant be done in house.
Where would you go to go direct?
Wed Nov 03, 2004 10:23 am » Post: #13 » Download Post
www.langcourt.co.uk
