NSR CRANK SEAL PROBLEM
Joe Blogs
Fri Sep 15, 2006 12:09 am » Post: #1 » Download Post
Hi all.
Im having a bit of a problem with my nsr 250 mc 21.
Its not burning all the fuel on the bottom cylinder, the result is that it is wrecking plugs flat out and there is sh*t coming out the exhaust.
I've been told that it could be that the crank bearing has shitted itself and taken out the seal and is sucking in gear box oil that's stuffing it. It doesn't look or smell like there is any petrol in the gear box sump.
Is there anyway of checking to see if the seal and bearing has shitted itself?
Any help would be great as it looks like Im going to be up for a bit of cash.
Fri Sep 15, 2006 7:05 am » Post: #2 » Download Post
Welcome to the site Joe, shame yor first post is about a bad NSR!
Firstly, it sounds like the jetting may be out on the lower cylinder, and it's runnin rich. Either that or for some reason the plug is not firng properly and it's not burning all the fuel.
You need to do a compression check to see if he cylinders are in good condition.
Joe Blogs
Fri Sep 15, 2006 8:54 am » Post: #3 » Download Post
Hi, i did a compression check about 1-2 months ago when it first started playing up, it came out both cylinders 130.
It still has standard jets in it, i thought that about the spark, would you say that it could/would be a ignition coil??
Fri Sep 15, 2006 11:02 am » Post: #4 » Download Post
Could be yes. We've had a few instances of bad supply to the coils, so check the spade connectors for pitting and security of fit.
Fri Sep 15, 2006 11:24 am » Post: #5 » Download Post
We've found dirty pins in the PGM connector too which can drop one cylinder. I think the lower cylinder is a black/yellow wire (of the top of my head though).
Fri Sep 15, 2006 1:06 pm » Post: #6 » Download Post
That yellow and black wire off the top of your head Steve, is where we plug you in at the lab! Laughing
Fri Sep 15, 2006 1:17 pm » Post: #7 » Download Post
When my centre crank seal died, the mixture still burned OK as long as the revs were kept up. It was the part throttle and bottom-end rpm that suffered the most. It still made 60hp though!! Smile
You can check the centre crank seal with the motor in place. Take the barrels off (keep the heads in place to save on gaskets) and mix up some pre-mix at 50:50. Fill the upper (left) side crank case with the pre-mix, and put a drip tray under the lower cylinder. You'll soon see if the seal is buggered!
I imagine there may be a very slight/slow amount of transfer between the cases over an extended time, but if the seal is shot, the level in the top case will drop noticeably in a very short time.
If the seal between the transmission and the crank has gone, it would be given away by white smoke from the RHS exhaust and the transmission oil level dopping as it is burned off.
Oh, and welcome to the Forum!
Fri Sep 15, 2006 3:49 pm » Post: #8 » Download Post
I did wonder why I had them Rolling Eyes
Fri Sep 15, 2006 4:44 pm » Post: #9 » Download Post
"It's ALIVE!!!" Very Happy
Sat Sep 16, 2006 3:31 pm » Post: #10 » Download Post
Come on Andy....now you're just getting carried away. The only time I saw Suh-teve move at any sort of pace was when the whisky was flowing.
Another whisk.........oh, help yourself mate Rolling Eyes
Sat Sep 16, 2006 5:42 pm » Post: #11 » Download Post
How dare you!
At least I could still move Mr Matt! Rolling Eyes
Andy knows I like a touch of whisky, and he saw the state I get into when I have a tad to much..... oh make that a double hey!?
Anyway back to this black and yellow wire off my head......
Joe Blogs
Sat Sep 16, 2006 10:46 pm » Post: #12 » Download Post
Hi, thanks for that so far guys, ill check em out and see how it turns out, also any ideas that are more simple than pulling the motor to bits would probably be better too.
Thanks
Sat Sep 16, 2006 11:24 pm » Post: #13 » Download Post
They'd be better in that they're easier, but sadly they wouldn't tell you if the seal is gone.
There really isn't much pressure built up between the two haves of the crankcase, so as Andy has pointed out, you're only likely to notice it at low RPM.
Have the exhaust off and take a good look up t the piston with a bright light.
Are the powervalves working properly?
Is there a good blue spark?
