Front brake lever with integrated fluid container ?
pbekkerh
Fri Jun 02, 2006 3:50 pm » Post: #1 » Download Post
Is there a Front brake lever with integrated fluid container available at a reasonable price ?
The original incl. the adapter, is so ugly and blocks the view to the thermometer. The tube on mine has been repaired with some goo, that doesn't make look any better.
I've seen a few, but they were billet things costing 2-400 pounds.
I am hoping to find one that is standard on some other bike and not too expensive.
Days2 Weeks1 Month3 Months6 Months1 Year Oldest FirstNewest First
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
cgallant
2001 Honda RS250
Fri Jun 02, 2006 4:38 pm » Post: #2 » Download Post
Not sure I would want to repalce the current setup with one that is all there. What happens then someting happens and brakes the res? Now you got to replace the entire assembly instead of the res cup.
Charles Gallant
nigel
Fri Jun 02, 2006 4:45 pm » Post: #3 » Download Post
i agree with charles
but if you still want to do it the cbr600rr uses that set up
Half the strokes, twice the fun
rc46
Sat Jun 03, 2006 6:37 am » Post: #4 » Download Post
worth pointing out that YOU will need to move the clocks as per your other post! ive got an all in one unit and the res is small but it made contact with the clocks on left lock. i had to buy new clipons with longer poles.
pbekkerh
Sat Jun 03, 2006 7:53 am » Post: #5 » Download Post
If I find one, what should the data for the unit be?
There must be some way of specifying capacity, bore-stroke, ratio or maybe how much liquid can be supllied or ?
Poul
MC21SE, KISS box
pbekkerh
Sun Jun 04, 2006 7:13 pm » Post: #6 » Download Post
Which non original front brake mastercylinder do you use ?
I am trying to find out which one I could use f,ex, ISR but I need these data for the NSR MC21, or the type of any nonoriginal that is known to work:
Cylinder diameter 17.5 mm
Cylinder diameter 14 mm
Reservoir capacity 50 cm3
Hydraulic thread M10 x 1.25
Weight 0.42 kg
Leverage ratio Adjustable: 5:1 - 3,8:1
Handlebar size 22 mm diameter
http://www.isr-brakes.se/products/mastercylinders/21-006.shtml
Poul
MC21SE, KISS box
rc46
Sun Jun 04, 2006 7:36 pm » Post: #7 » Download Post
im using ISR radial with intergrated Resivor. it dosnet have a great capacity but works well i think it was a 17.5mm bore but best thing to do is call this guy he'll tell you exactly what size you need.
http://www.p3unlimited.com/master_cylinders_front.htm#radial
here is a pic of mine before i change the clipons so i could tunr the bike LOL oh yeah and then i needed new throttle cable's as originals are to short with new clipons. Im still getting use to the feel of the new brake but hand on heart i thought the original unit was better than this. Maybe im just not used to the feel yet!
http://www.bikepics.com/pictures/530306/
mick
Sun Jun 04, 2006 8:20 pm » Post: #8 » Download Post
Having seen RC46's lever 1st hand i can assure you it is 1st and foremost the the best enginered res / lever i have ever seen but also a work of art, except I wouldnt like to pay for one $$$$$$$$$$$$$$$$$ Razz
pbekkerh
Sun Jun 04, 2006 8:32 pm » Post: #9 » Download Post
I did send an e-mail but he didn't answer yet
The ISR looks fantastic. Any pics of the RC46 unit ?
Poul
MC21SE, KISS box
rc46
Mon Jun 05, 2006 6:59 am » Post: #10 » Download Post
Na! the VFR8 is long gone, Iv got a intergrated unit on the CBR6 BUT the calipers on the 97 model are only 2 pistons, so not sure that would work.
For all its cost, you could get a VFR8 unit from ebay for only a few $/£ and give it a go, ive seen them go for as little as £10 with a scruffy lever. and if it didnt work you could sell it on.
As for P3 best to call him, he'll chat for ages and youll end up with the right one.
