Water pump removal
SPENGILLY
Water pump removal
Sun May 21, 2006 11:16 pm » Post: #1 » Download Post
Do you put a socket on the Prop to take it off? My new clutch cover should be in soon so I need to change to new cover. R model, any help would be cool.
Mon May 22, 2006 11:40 am » Post: #2 » Download Post
Er, you just undo the three bolts - from memory.
SPENGILLY
Tue May 23, 2006 2:32 am » Post: #3 » Download Post
The 3 bolts will remove the cover. I need to remove the shaft, seals & bearing from the engine case to put on the new case/clutch cover (wet).
Tue May 23, 2006 7:00 am » Post: #4 » Download Post
Ah, I'll shut up and go away then! Wink
