tips on lifting the rear end on a 28?
sparky
Fri May 12, 2006 8:14 am » Post: #1 » Download Post
is there a way to jack up the rear wheel on a proarm without a proper stand?
nowhere to put a jack unless I take the pipes off.
rc46
Fri May 12, 2006 8:30 am » Post: #2 » Download Post
Did you want to take the swing arm off? If not you can use a abba stand, bit expensive but holds the bike solid and uses the swing arm pivot points to support the machine.
Fri May 12, 2006 9:33 am » Post: #3 » Download Post
Not in the same fashion as using two axel stands on a conventional swing arm no.
sparky
Fri May 12, 2006 3:11 pm » Post: #4 » Download Post
I want to take the wheel off for painting.
there is a guy selling stands on ebay but doesn't know the size of the pin for the NSR. anyone know the size for the stand pin going into the hub?
tuanmynsr
    Send private message View user's profile Send e-mail Yahoo Messenger
Sat May 13, 2006 2:48 pm » Post: #5 » Download Post
the pin s/b around 30 -31 mm. Bigger than 31.50 mm will not fit.
Ducati 996
Honda MC28
RS chassis w/ CR80
76 Honda Z50
sparky
Sat May 13, 2006 3:43 pm » Post: #6 » Download Post
thanks
