1984 ns250r mc11 parts
rubberneck812
Wed Apr 26, 2006 2:11 am » Post: #1 » Download Post
Sad just got a 1984 ns250r mc11. it needs a front piston. I need a parts and service manual. Can't seem to find anything on line. I live in florida so any help would be great!
RVT2002
Wed Apr 26, 2006 3:31 am » Post: #2 » Download Post
Your best bet is Japan. MC11 are like NS400 ,pistons are hard to find. Sad
BOSOZOKU
Wed Apr 26, 2006 6:46 pm » Post: #3 » Download Post
From what I have been told the NS400r pistons are unavailable now even from Honda.
So good luck with the search maybe worth having a chat with Jamie ( http://www.dreamgate.ne.jp/nsr/index.html ) as he is out in Japan and maybe able to put you in touch with some one he can source you some pistons.
BOSOZOKU Wink
MC21R Repsol replica
SC36 'Fire storm'
RG250 MK3 GAMMA 'WALTER WOLF'
DR350SEV winter hack
rubberneck812
Wed Apr 26, 2006 10:42 pm » Post: #4 » Download Post
thanks for the info! any is better than none.
RVT2002
Wed Apr 26, 2006 11:11 pm » Post: #5 » Download Post
If you know the part # for the pistons its probably easier to find the parts.
rubberneck812
Sun Apr 30, 2006 11:59 pm » Post: #6 » Download Post
can't seem to find any part#s. found ns400r piston part#s, but i don't know if they are the same? I'm going to look into getting pistons made or put on cr125 jugs&pistons if bore&stroke are the same and don't run the power valve.
mat grant
Mon May 01, 2006 9:18 am » Post: #7 » Download Post
Hi,
try www.ns400r.co.uk - there is a parts list on there, from the Honda microfiche, there is also a forum and if you put 'piston' in the search you'll see it's been discussed a lot!!! Solution vary from geting 64mmpistons and reboring/replating, to CR125 barrels and pistons (not seen one of these on the road yet...but I know of 2 being made, one is quite near me...
You can get B grade NS400 pistons from David Sliver in the UK, but the 400 is a 57mm bore and the 250 is (I think) a 56mm bore. But you may find an NS400 barrel and piston on ebay, that would be the cheapest way to get the thing running.
Cheers, Mat.
rubberneck812
Mon May 01, 2006 2:17 pm » Post: #8 » Download Post
thanks for the info mat, i'll look into that option too.
