Oil Injector Pump Help
longrider
Fri Apr 14, 2006 3:40 pm » Post: #1 » Download Post
Help! I'm reassembling an MC21 for a friend, but know very little about it. Got the clutch installed and the cover on using an on-line parts microfiche as a guide, but when I fill the 2-stroke oil tank it drains down into the clutch cover. Trying to see how it works, it makes no sense to me at all. Can anybody tell me how the injector pump works and what might be wrong?
TIA,
"4 bikes is not enough"
Fri Apr 14, 2006 6:09 pm » Post: #2 » Download Post
There's a little seal on the underside of the 2/ oil pump. If it slips down the shaft the 2-stroke oil tank contents will drain into the gearbox.
Sassy owners leave the tank topped right up as an early warning system of this little beaut.
I think there's a pic of it somewhere (Andy??) but I can't find it.
longrider
Fri Apr 14, 2006 6:57 pm » Post: #3 » Download Post
Thanks!
That must be item #9 and 10 in frame E 14. I'll get the pump off this weekend and check it out.
eric
Fri Apr 14, 2006 7:08 pm » Post: #4 » Download Post
Yep, that's the culprit!!
longrider
Sat Apr 15, 2006 8:05 pm » Post: #5 » Download Post
OK, I can't find it on the parts fiche, but I think I'm missing a piece. Not only do I not have the o-ring and washer #'s 9 & 10, I don't have a shaft to put them on. Is there supposed to be a shaft that meshes with the helical portion of the waterpump drive shaft and goes up the passage to drive the oil injector pump? If so where do I get one? Or should I just run premix?
ahug030
Sat Apr 15, 2006 9:49 pm » Post: #6 » Download Post
yes there is, the shaft can fall out and go missing if you take the pump off as it isn't held into the pump end by anything but the rubber seal. I would suggest a wreckers, only not in the U.S. because of rarity. I imagine running premix would be a pain if you ride the bike alot.
'87 MC16
longrider
Sat Apr 15, 2006 10:18 pm » Post: #7 » Download Post
Thanks. We'll see what we can do.
newbie
    Send private message View user's profile Send e-mail Yahoo Messenger
Sun Apr 30, 2006 4:25 am » Post: #8 » Download Post
Try Tyga. www.tygaperformance.com These guys know everything about MC21s
jclstepp
Sun Apr 30, 2006 4:27 am » Post: #9 » Download Post
Hey guys, he's referring to my bike, I found a site that can help with OEM parts!
http://www.apexleisure.co.uk/NSR250MC21.htm
can anyone tell me the part number for the shaft that the oil pump washer and o-ring fit onto?
