Rear brake mc21 + tune Question
horde
Tue Mar 21, 2006 5:18 am » Post: #1 » Download Post
hey guys,
quick question, can anyone tell me how thick a set of rear pads are for the mc21? Reason I ask is because my pads look fine with enough meat on them, but the piston is quite a way out and the caliper is flexing a bit. I believe this flexing action was responsible for snapping a bolt off the rotor to wheel. Sad
Also, has anybody thrown their bike on a tune scope? Any idea's what exhaust temps and c/o's should be?
Thanks guys!! Smile
........."I love the smell of 2-stoke in the morning.......Smells like victory"............
MC21 Pentax SP...... TYGA'D
rc46
Tue Mar 21, 2006 7:47 am » Post: #2 » Download Post
There should be wear indicators on the pads, take them out and have a look, if the pads are uneven, blued or less than 3mm of meat id replace them, make sure its the correct pads for the caliper! as a rule i always change my rears every 10k regardless and fronts around 6K if not before, YOU CANT SKIMP ON BRAKES! as for breaking a bolt this shouldnt happen, is the disc warpped? is the caliper on correctly?
Cant help with the other stuff never tried, Cheers
horde
Tue Mar 21, 2006 11:27 am » Post: #3 » Download Post
Hey rc46, yeah there is about 3mm on each rear pad, so I guess I'll change them then. I'm guessing they come new with bout 8mm-10mm of pad when new?
Caliper is on correct, rotor is not warped, slides lubed, etc........ I was mucking around when it broke, excessive rear braking.
Thanks mate!
