Gear Box oil looks like baileys!
Markus
Thu Feb 23, 2006 8:28 am » Post: #1 » Download Post
My Gear box Oil looks like baileys.
Its a MC21 SP so it has a dry cluth.
I want to replace the water pump seal on the left hand side.
But before i go through the long process to find parts, I just wanted to ask if there are any other parts i might need to get.
plus i cant open the parts manual so i cant find the part number has anyone got access to it, and does anyone know if the parts are the same as any other honda models. (as NSR parts are very hard to come by!)
thanks so much for your help,
Markus
mick
Thu Feb 23, 2006 8:32 am » Post: #2 » Download Post
To see the manual you may need to increase you screen resolution. If you dont see the menu you will need to download java from java.com
Markus
Thu Feb 23, 2006 8:35 am » Post: #3 » Download Post
mick wrote:To see the manual you may need to increase you screen resolution. If you dont see the menu you will need to download java from java.com
Ok i feel a little stupid i tried again and it worked.
maxim
Thu Feb 23, 2006 9:04 am » Post: #4 » Download Post
Your gearbox oil has emulsified... It means that unfortunately, you have moisture/water getting in there from somewhere, which needs to be rectified.
Chester362
Thu Feb 23, 2006 11:43 am » Post: #5 » Download Post
The water pump shaft might be worn also.
You generally find grooves where the seal lips bear on it.
You can sometimes get away with just fitting a new seal, if they`re deep though & if you can afford a new shaft, it gives you a bit of peace of mind.
