HONDA RS250 stator, ECU,big Cabs on NSR250...MC28
Hung
Fri Feb 03, 2006 2:36 am » Post: #1 » Download Post
Who has it on your NSR250? One of my friend's NSR250 just done with it, I was told the NSR250 MC28 is going unbelieveable fast? I just very curious how the engine works? any opinion?
1996 HONDA RS250
1995 MC28 NSR250 SE red/white/green
1994 MC28 NSR250 sp W/ RS250 engine
Fri Feb 03, 2006 3:00 am » Post: #2 » Download Post
This is basically a semi F3 conversion and is gonna be something that StephenRC45 will be trying.
The RS rotor will allow the engine to spin up faster 'cos less weight on the crank. The RS PGMII obviously gives good timing with no restrictions, but depending on year maybe need retarding for unleaded fuel.
The big carbs have been done by many and give good top end power, especially on a 'built' mota.
You'd be looking at 70+ ponies.
big pete
Fri Feb 03, 2006 4:32 am » Post: #3 » Download Post
what year RS carbs should be used on a 28?
1994 NSR250SE
RVT2002
Fri Feb 03, 2006 4:33 am » Post: #4 » Download Post
Would a 92 RS250 carbs work on MC21 ?
Fri Feb 03, 2006 6:49 am » Post: #5 » Download Post
Any carbs will work, but you'll just have to put in the hours to set them up.
I've used 91, 92, 96 RS250 carbs. I've also tried a pair of CR500 carbs. Don't expect CR500 jetting to work though!
RVT2002
Fri Feb 03, 2006 8:09 am » Post: #6 » Download Post
Cool! So if you use a rs250 stator then you'll lose your lights right ?
Fri Feb 03, 2006 11:46 am » Post: #7 » Download Post
You will also need to strip your motor and re-mechine where the stator sits as it wont fit on stock nsr crank cases.
Fri Feb 03, 2006 8:20 pm » Post: #8 » Download Post
I was thinking of alternative carbs this morning. Having worked with Scott V on his RS carbs I can see why they would be a great addition to a track bike even if they didn't add any power. They are so easy to work on.
Since RS carbs are quite hard to find, can CR carbs fit. How could you join two together?
Fri Feb 03, 2006 8:36 pm » Post: #9 » Download Post
You use 2 cables, just like the RS does. CR500 carb is 38mm the same as the RS.
Fri Feb 03, 2006 11:32 pm » Post: #10 » Download Post
So I can use 2 CR500 CR carbs mounted on RS carb boots (if I can find those!)?
Fri Feb 03, 2006 11:41 pm » Post: #11 » Download Post
Yes
Hung
Sat Feb 04, 2006 3:12 am » Post: #12 » Download Post
So...what is F3 conversion? and which year model RS250 Stator,ECU, CAbs has the best performance?
1996 HONDA RS250
Sat Feb 04, 2006 1:41 pm » Post: #13 » Download Post
Sorry to hijack your thread Hung, but can anyone tell me the part numbers for the '92 RS250 carb boots.....Scott, Maxim?
Where's the best to get em?
Jim
Sat Feb 04, 2006 3:29 pm » Post: #14 » Download Post
Carb "insulators" for the '91: #16210-NF5-710 (front); 16220-NF5-710 (rear).
not sure if that helps given you're after the '92 numbers, but maybe a bit. Confused
-Jim
'93 MC21
maxim
Sat Feb 04, 2006 3:33 pm » Post: #15 » Download Post
Mine are 1991 Tom, and no longer available... Sad They are actually made from Hens Teeth.
