Gearbox oil
fstnsr
Gearbox oil
Fri Dec 09, 2005 12:45 am » Post: #1 » Download Post
hey
is rock oil's gear lite the correct oil for my se?
thanks
94 mc28 SE
Fri Dec 09, 2005 2:00 am » Post: #2 » Download Post
NSR-WORLD Rockoil Page.
fstnsr
Fri Dec 09, 2005 3:52 am » Post: #3 » Download Post
hey andy
this stuff is rock oil "lite gear oil" is it ok for it. the other they had was just called "gear oil"
94 mc28 SE
Fri Dec 09, 2005 4:13 am » Post: #4 » Download Post
Official recommend transmission oil is Honda Ultra U SAE 10W-30, or API SE 10W-30 engine oil.
We recommend Rockoil G.R.O. fully synthetic transmission oil for the SE/SP.
Ask the shop if they have something suitable for dirtbikes like the CR's or RM's if you are worried!
ahug030
Sat Dec 10, 2005 9:32 pm » Post: #5 » Download Post
My gearbox oil is white Shocked so probably time for replacement!
'87 MC16
fstnsr
Sat Dec 10, 2005 9:34 pm » Post: #6 » Download Post
as far as i know white is bad as in u have a watwer leek.
94 mc28 SE
Sun Dec 11, 2005 1:31 am » Post: #7 » Download Post
Indeed, white transmission oil can be a bad sign.
It could just be that the bike has often stood for long periods between use, and that condensation has built up inside the transmission case. The condensation will cause the oil to emulsify, turning a greyish colour, and break down.
Change the oil, run the bike to normal operating temperature, then drain it again to flush all the "dead" oil. You may have to do this a couple of times to completely clear the casings. Keep an eye on the coolant level. If the level starts to drop and the oil continues to turn a milky grey colour, then it is most likely the water pump seal that has failed.
There are a couple of oils on the market that have a "milky" appearance however, but they are usually coloured, not grey.
I will contact RockOil to ask if their light gear oil is suitable for the NSR, but I would not recommend it until I have the facts.
ahug030
Sun Dec 11, 2005 3:13 am » Post: #8 » Download Post
What problems would tainted gearbox oil cause? I've got other issues with the bike, just wondering how related these things might be. Its in the shop right now so will definitely inform the mechanic, although I would rather do it myself as labour costs $76 an hour Rolling Eyes
'87 MC16
rc51paul
    Send private message View user's profile Yahoo Messenger
Mon Dec 12, 2005 4:40 am » Post: #9 » Download Post
The tainted oil will not do it's job correctly. Get rid of it. You can also add some diesel in when you change the trans oil to flush the system. Don't leave it in though, just use it to flush out the old crappy oil. I see this a lot on bikes which are left outside. Hope that helps.
To much HP is barely adequate!
motulman
gear box oil
Sun Dec 18, 2005 8:57 am » Post: #10 » Download Post
hello everyone i was wondering what tranny oil to run and from what i have read here that i can use the same oils i use in my yamaha rd's basically a 10-30 gearbox oil like lets say motul? if not please advise! and thanks
DAYTONA SPECIAL,74 RD350 LONG ROD, 2 RD200 ELECTRIC'S,88 NSR 250RG, MICRO SPRINT CAR W/CR 250 ENG
rc51paul
Sun Dec 18, 2005 3:42 pm » Post: #11 » Download Post
I use a 10W30 transoil from motul. Works great Smile
