Tyga Pipes Fitment
Page 1 of 3  Goto page 1, 2, 3  Next Download Topic
mick
Tyga Pipes Fitment
Mon Oct 31, 2005 9:18 am » Post: #1 » Download Post
i fitted the new pipes on saturday and am generally happy with them but i have a small issue
the right hand pipes is fouling the swingarm slightly and is stopping application of the rear brake, is this normal ??
see pics below although not sure how clear the problem is
nsrmonkey
Mon Oct 31, 2005 9:20 am » Post: #2 » Download Post
cant help mate but just wanted to say it looks real nice, how i want a rothmans spray job..........
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
Mon Oct 31, 2005 9:48 am » Post: #3 » Download Post
Definitely not right. I'm sure Matt will be along shortly...
Mon Oct 31, 2005 10:57 am » Post: #4 » Download Post
You should be shot if you spray that stock R body work billy!
rc46
Mon Oct 31, 2005 11:00 am » Post: #5 » Download Post
I would contact matt, dosent look or sound right, did you hook it all up lose first? and see if there was room to move it around, Silly but did you get the right chambers? they did look like mine which are getting done as we speak, as soon as Mick calls me ill ask and let you know what he says,
MMMMMmmmmm Confused
Actually, dose it foul the fairing? near the back bottom screw? it suposed to foul the fairing and you just put a spacer in, if its not doing this there is sopmething wrong!
nsrmonkey
Mon Oct 31, 2005 11:39 am » Post: #6 » Download Post
StephenRC45 wrote:You should be shot if you spray that stock R body work billy!
just for that i am gonna do it with spray cans in the middle of winter outside.
that'll show ya MMMWWWOOOOHAHAHAHAHAHAHAHA Twisted Evil
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
mick
Mon Oct 31, 2005 11:40 am » Post: #7 » Download Post
yes it does foul the fairing and i was aware of that issue before fitment
Mr T
Mon Oct 31, 2005 1:24 pm » Post: #8 » Download Post
Sounds like it might be MC28 pipes you've got fitted. I've got a set of endurance racing pipes fitted on my 21 that were built for the 28 and they foul in the exact same places you're describing. I've seen endurance racing pipes fitted on another 21 with no problems, thats when I found out that the pipes were slightly different that they manufactured for the 21 & 28.
Mon Oct 31, 2005 1:29 pm » Post: #9 » Download Post
That was my first thought, but I believe they now have a dual jig, so all pipes fit either bike.
mick
Mon Oct 31, 2005 1:29 pm » Post: #10 » Download Post
Mr T wrote:Sounds like it might be MC28 pipes you've got fitted. I've got a set of endurance racing pipes fitted on my 21 that were built for the 28 and they foul in the exact same places you're describing. I've seen endurance racing pipes fitted on another 21 with no problems, thats when I found out that the pipes were slightly different that they manufactured for the 21 & 28.
on TYGA's site the pipes are listed as being for the 21/28 so judging by that should be the same pipes for both models???
cgallant
2001 Honda RS250
Mon Oct 31, 2005 3:38 pm » Post: #11 » Download Post
Mick,
I would say that the right hand pipe is not for an MC21, or you have an aftermarket rear shock with added ride hieght.
You can do a couple things.
1. If it's a pipe for an MC28, get one for an MC21.
2. If you have added ride height, you can create a small spacer for the mount that moved the pipe down a little to clear the swing arm.
Charles Gallant
mick
Mon Oct 31, 2005 3:50 pm » Post: #12 » Download Post
to be honest i'll probably just fettle a bracket up to lower the pipe slightly
tyga probably wouldnt take the pipe back as it has a small scuff on it where it's been hitting the swing arm
Mon Oct 31, 2005 6:32 pm » Post: #13 » Download Post
Spoke with Matt a week or so ago about fitting MC28 pipes to an MC21. He said they wouldn't fit and the two pipes are different.
Must admitt that they don't look to bad. Does the swing arm foul the pipe, or is it just the rearset?
nigel
Mon Oct 31, 2005 6:50 pm » Post: #14 » Download Post
i had the same problem with fouling the swinger arm on my 21
if i remember correct i spaced it out with a washer and elongated the mouning hole on the pipe slightly and that cured the problem
didnt have the brake prob as i have rearsets fitted
Half the strokes, twice the fun
rc46
Mon Oct 31, 2005 8:36 pm » Post: #15 » Download Post
Sad not good, if thats true that means im gona get mine back from mick with the same problem... Sad i hope Matt chips in soon for a reply the tyga site indeed lists both 28 and 21 pipes as the same! if there diffrent they should be sold that way not hacked until they fit or sold with a mounting kit. ......anyone else had the same problem?
http://tyga-performance.com/site/product_info.php?cPath=44&products_id=518&osCsid=fab361d75efbfe92824a027b6bc96247
it looks good here, but cant tell if its hitting the swing arm, rearset looks ok
http://tyga-performance.com/site/images/EXCS-0005-1.jpg
