NEED SOME MAJOR HELP!!!
CDNNSROWNER
Fri Aug 12, 2005 2:12 am » Post: #1 » Download Post
I have a 91 MC21 SE, I just bought a used motor and installed it. After a few kicks the thing started up and was running. I shut it off and started again, and so on and so on. I felt confident that the bike would run so I decided to go to the gas station to fill up the tank with some premium gas. As I pull out the drive way, I forgot to open the fuel valve so the bike stutters and dies. Now I can't get the damn thing to start up again. What could be the problem. Any help/advise would be greatly appretiated.
invigiator
Fri Aug 12, 2005 2:42 am » Post: #2 » Download Post
Open the fuel vavle?
Put fuel in the tank?
Try push-starting it?
Check the plugs?
MC28 SE -sold-
MC21 with RS250 engine -for sale-
MC21 race bike -soon for sale-
CDNNSROWNER
Fri Aug 12, 2005 4:03 am » Post: #3 » Download Post
First off thanks for the reply. And yes I have tried all of those procedures and more but still noting.
fstnsr
Fri Aug 12, 2005 4:34 am » Post: #4 » Download Post
Have you changed the plugs? Sometimes mine look good but are stuffed.
94 mc28 SE
estrol
Fri Aug 12, 2005 5:33 am » Post: #5 » Download Post
Keep it on reserve. The ON switch needs a few liters of petrol for it to flow. All it needs is a jump start. The fact it was running then died. It should only be that. Unless there is no fuel filter/strainer, then it would clog the carb. Because when at ON, the fuel passes through the higher intake hose in the tank. The reserve passes throught the bottom part of the hose or fuel cock. Definitely not something to panic on. Just a bummer getting it to fire again, might take you the whole street block.
ride it like a horse
Fri Aug 12, 2005 6:35 am » Post: #6 » Download Post
To check the fuel is getting to the carbs, open the float bowl drains a bit and ensure fuel flows from them. If it doesn't, you have a fuel problem!
If that's good, check you are getting a spark.
CDNNSROWNER
Fri Aug 12, 2005 4:04 pm » Post: #7 » Download Post
Thank you all for your help, I will definitly work on those probs today and hopefully get her up and about.
CDNNSROWNER
Sun Aug 14, 2005 8:54 pm » Post: #8 » Download Post
now i have tried almost everything and still not running, bout to tow the damn thing to the pound. HELP ME!!!!!!
Jeff SZ
Sun Aug 14, 2005 11:13 pm » Post: #9 » Download Post
Check spark, check fuel flow, check plugs, check compression ? I f you have all those it should start.
Mon Aug 15, 2005 6:33 am » Post: #10 » Download Post
Did you do what I suggested? And the results?
CDNNSROWNER
Mon Aug 15, 2005 2:44 pm » Post: #11 » Download Post
It's a miracle..I finally got it to start up. I had to hook it up to my buddies car and we practically dragged it for 1/2 km for it to start up. But now theres another problem, the bike picks up very poorly and you need to play with the throtttle and clutch (very high RPMS) in order to get it going or it will stall. My current mods are: wire splice, tyga pipes/cans, carbon reeds, modded airbox. I live in Canada so do you think that the weather could be affecting the performance since it is colder here (26-29^C avg.).
And yes Dave I did try the things you told me,maybe thats what got it going thanks alot.
Also does it matter which order of the wires for the coil connectors.
Mon Aug 15, 2005 3:11 pm » Post: #12 » Download Post
Ah good.
It sounds like the jetting may be out if there's no power. Do you know what jets are in the carbs? Has it been set up to match the mods you've done?
Jeff SZ
Mon Aug 15, 2005 4:31 pm » Post: #13 » Download Post
Sound like it had it seized ? Check your compression.
Tue Aug 16, 2005 6:38 am » Post: #14 » Download Post
I thought that too, but why would running out of fuel sieze the bike - assuming he's running an oil pump?
Jeff SZ
Tue Aug 16, 2005 9:28 am » Post: #15 » Download Post
Did you bleed the pump ?
