  • NSR250 Forums Index ‹ NS Discussion
ns250f
drebins
ns250f
Tue Oct 07, 2014 5:02 pm » Post: #1 » Download Post
Hello!
Two months earlier i bought this beautiful old school Honda NS250F
This bike was sitting in the garage for almoust 10 years, and then i bought it.
My friend cleaned both carbs, changed fuel filter, hoses, made nev ignition key and engine started.
Now i need to change cillinder gasket and find out why ATAC sistem doesn`t work...
Tue Oct 07, 2014 5:14 pm » Post: #2 » Download Post
That's cool! And welcome to our first ever forum member from Latvia! Smile
drebins
Tue Oct 07, 2014 6:26 pm » Post: #3 » Download Post
thanx Wink
I will keep posting updates.
Maybe someone knows where i can buy a head gasket?
Wed Oct 08, 2014 11:38 am » Post: #4 » Download Post
I did a quick search and only found complete gasket sets. I think you would have more luck if you get a Honda parts guide. You sometimes see them in ebay and more likely on Yahoo Japan.
I use www.jauce.com to buy from Yahoo
drebins
Sat Oct 11, 2014 4:26 pm » Post: #5 » Download Post
i had a problem, one cylinder doesn`t work, there is too much fuel pumping and spark gets wet.
what size is main jet`s in the carbs? Because one is bigger than another, maybe that`s why it flushes fuel too much.
And i noticed that there is something broken in the exhaust, we cut it open and the noise was from the whistle, i threw it away, and welded back.
Sun Oct 12, 2014 1:39 pm » Post: #6 » Download Post
It is common for "Vees" (both 2-stroke and 4-stroke) to have different size main jets (and often needles and/or power jets) in the front and rear cylinders.
If you look on the NSR carb settings page in the Tech section, you will see that even the models with the same main jet have different needles front and rear.
Yuri
Sun Oct 12, 2014 1:40 pm » Post: #7 » Download Post
It is normal for v twin engen to have different size jets
Look at your needle and seat if the still work fine
drebins
Sun Oct 12, 2014 3:52 pm » Post: #8 » Download Post
Is there somewhere carb settings for mc11 like this?
drebins
Sun Oct 12, 2014 3:56 pm » Post: #9 » Download Post
this was how bad carbs looked before general cleaning
drebins
Sun Oct 12, 2014 4:04 pm » Post: #10 » Download Post
front cilinder had problem with gasket, found out that bolts were loose.
ATAC system was totally sticked together with dried oil and gas.
drebins
Sun Oct 12, 2014 4:14 pm » Post: #11 » Download Post
small video, one cylinder works only, still trying to solve the problem. Cold engine runs ok, but couple minutes later only on 1 cylinder
https://www.youtube.com/watch?v=x8q7Fw2hGSA&feature=youtu.be
FranciscoGray
Fri Nov 20, 2020 4:45 am » Post: #12 » Download Post
Jubins wrote:i had a problem, one cylinder doesn`t work, there is too much fuel pumping and spark gets wet.
what legal steroids are sold at gnc size is main jet`s in the carbs? Because one is bigger than another, maybe that`s why it flushes fuel too much.
The Honda NS250F and the Honda NS250R are filled with bold style and a newly designed liquid-cooled 2-stroke 90 Degree V-twin engine (displacement is 249cm3). ... The NS250F/R was developed using the latest sophisticated technologies gained from the 1983 MotoGP world Champion racer "Honda NS500".
primetboosters
Tue Feb 23, 2021 12:11 pm » Post: #13 » Download Post
Soo cool
Tue Feb 23, 2021 2:42 pm » Post: #14 » Download Post
Hi drebins, did you find the problem and get the nsf sorted ?
NS Discussion
