MC21 Gearing
The17thPope
MC21 Gearing
Sun Feb 04, 2018 6:04 am » Post: #1 » Download Post
An oldie but a goodie.
What are the types of gearing set ups that you lads/lasses (humans if the others aren't politically correct) Rolling Eyes are running on your NSR's?
Mine is an MC21
Modified OEM air box,
HRC Flywheel
Standard PGMIII
Derestricted
TYGA Pipes
Thinking of 15/42
And go
Popes
Owner - SP 2 Stroke Motorcycle Parts & Imports
Live 2 Ride
Ride 2 Live
Honda 00 VTR SP1
Honda 02 VTR SP2
Honda 93 NSR250R MC21 SP
Honda 02 NSR150 SP
(See. Pattern;) )
Suzuki 92 RM250
Aprilia 98 RS250 Mk 2
Suzuki RGV250 VJ22
kostaskk
Thu Feb 08, 2018 2:14 am » Post: #2 » Download Post
mc21 frame ( with aprilia rs250 mk1 front suspensions and brembos)
sp front wheel. the back is 17' but not sp yet
lightened to about 122 kg with a little fuel in.
keihin pwk38 airstrike carbs,
open carbs
velocity stacks
aluminium 38mm short manifold
tyga hi-flow reeds.
heat-shield
ported crank-case
epoxy to the oil pools like honda rs models.
stock pistons
mc21 r model cylinders
2 top cylinder sp heads..
0,4mm cylinder base gaskets
ported exhaust ports (to get more wide and more height,tryed to have as flat posible the top of the port like mc18 cylinders)
8 heat range sparkplugs
power valves are always 100% open (pv mechanism removed)
lightened mc21 flywheel,lightened clutch.
kickstarter and mechanism removed,no oil pump
jha mc18 1989 exhausts with exhaust wrap
mc18 1988 pgm1 electriks (aprilia rs 250 coils)
engine is mc21 but i fit a 1989 mc18 gearbox (and clutch is 1989)
gearing is 14-40 feels short but builded for small tracks. probably because the 1989 is one of the most short gearboxes and also designed for a 18'rear wheel.
pulls nice from 7500rpm and you can ride it at low rpms with no problem. (this is good,remember power-valves dont work)
it get's to a mad pulling at 10.000
rpms get very fast up to 12.500+ max rev is about 12.800- 13.000 (clock readings)
from 2nd gear and 10.000rpm to 4th gear and 12.500 it takes about 6 seconds or less
smaller diameter front spockets may produse more chain and spocket wear.
next engine will be with
some crazy ported mc18 cylinders
2 rm125 single ring pistons, skimed mc18 heads
and the right exhausts for over-rev
16-40looks good if there is posible to fit a 16 spocket.
racer241
1992 Honda NSR250 MC21SE
Sun Feb 11, 2018 4:48 pm » Post: #3 » Download Post
15/42 Is what I have been running for a couple of years now. Good in the canyons and works good for the tracks in my area. It does rev a bit high on the highway though. My set up is very similar to yours.
1979 RD400 Datona Special
1992 NSR250
1998 HRC RS125R
2007 Aprilia Tuono
