TPS switch plug
NSRetro
TPS switch plug
Sun Jan 21, 2018 2:07 am » Post: #1 » Download Post
Hi Guys,
I can't seem to unplug the TPS switch, it's got an accumulation of grit from the last 28 years I think. The lugs won't depress due to the latter... I need to adjust my power valves...any tips? Thanks guys
bushman
Tue Jan 23, 2018 7:25 pm » Post: #2 » Download Post
You can adjust the R/C v/vs without disconnecting the TPS http://www.nsr250.net/forums/viewtopic.php?t=11226&highlight=rpm
apf
Wed Jan 24, 2018 10:52 pm » Post: #3 » Download Post
I had this issue the first time too. But basically you pull the center tab up and carefully wiggle the plug out. I've found that putting on a pair of thick latex gloves helps tremendously with the grip.
Just keep repeating the process carefully until it comes free.
