Looking for part number help
MC21 marshall
Wed May 03, 2017 4:41 am » Post: #1 » Download Post
Hi Guys
Im having a bit of trouble locating the number for the rear sprocket parts.
I really want to get a spare set of the threaded flange tubes that go in to the cush drive from the sprocket.
At the moment I keep having to remove them from one sprocket to another when i adjust my gearing for the track I'm at.
The parts list does not show the item as a separate part.
Is it a case of buying a new OEM sprocket for cannibalism of the parts required ?
It smokes a lot is that right !
Wed May 03, 2017 5:28 am » Post: #2 » Download Post
Does this help?
http://tyga-performance.com/product_info.php?cPath=72_1036_79_120&products_id=1512
Wed May 03, 2017 7:59 am » Post: #3 » Download Post
The sprocket carrier bolt codes begin 90128KV3, so MC21 I believe has 830/831 at the end
MC21 marshall
90128KV3 830 0r 831
Wed May 03, 2017 9:00 am » Post: #4 » Download Post
So its called a special sock.
Well that what good old google tell's me.
I have still yet to find an image of the part to be double sure before ordering it.
Wed May 03, 2017 9:55 am » Post: #5 » Download Post
It might be worth sending an email to CMSNL to ask if they have any in stock to send you a photo
Wed May 03, 2017 1:47 pm » Post: #6 » Download Post
I use an mc18 sprocket carrier on my 21, makes it a lot easier to change sprockets, see if you can get hold of a used one,(should be cheap enough on that there auction site ) and you'll see what i mean, might be easier than trying to locate the new bits your'e after.
