NX5 throttle assembly
TomB
Sat Apr 01, 2017 6:23 am » Post: #1 » Download Post
Does anyone know where I can get a replacement throttle assembly (plus tube) for a NX5? I don't care if it's original, just want something that works well.
Sat Apr 01, 2017 8:44 am » Post: #2 » Download Post
Have you tried Dennis Trollope,he has had various throttle assembly parts for sale for honda RS's, wont be cheap though coming from Dennis, i think he does replacement ones as well, ie Domino etc.
sennidott
Mon Apr 03, 2017 12:13 pm » Post: #3 » Download Post
I have a spare Domino throttle if that would help?
TomB
Mon Apr 03, 2017 8:55 pm » Post: #4 » Download Post
Todd
Does the Domino throttle fit as good as the Honda? - I've only ever had the Honda throttle, but would be happy to give it a try.
MarkR
Sun Apr 16, 2017 8:39 pm » Post: #5 » Download Post
Tom,
I have a Domino throttle. Problem is that it doesn't accept the standard NX5 cable.
NX5 throttle housing is NLA. Have you looked at TZ 5KE/4DP? They look pretty close to me.. DTR have them on ebay, but I'm sure there will be other folks who stock them. I'll probably be going that route next time I need one.
If it ain't broke, fix it until it is.
TomB
Mon Apr 17, 2017 8:37 pm » Post: #6 » Download Post
Mark
I fitted a TZ housing and tube today, and it seems a perfect fit. The Honda cable fitted straight on.
MarkR
Tue Apr 18, 2017 9:38 am » Post: #7 » Download Post
Pleased to hear that you're sorted, Tom.
Remember to put plenty of slack in the cable... It'll help to tame your new found bhp I've been hearing about... Wink Laughing
tdijam
Thu Apr 27, 2017 7:43 am » Post: #8 » Download Post
I'm told the Honda throttle tube is identical to the Yamaha part , I've not compared the two parts , so I can't say for sure that's correct.
MarkR
Thu Apr 27, 2017 7:55 am » Post: #9 » Download Post
It's entirely possible that Honda and Yamaha both outsourced to the same supplier
Thu Apr 27, 2017 8:06 am » Post: #10 » Download Post
Also look at Honda rs125 ones, i have rs125 ones, and externally they look the same.
MarkR
Thu Apr 27, 2017 10:36 am » Post: #11 » Download Post
Lesviffer750 wrote:Also look at Honda rs125 ones, i have rs125 ones, and externally they look the same.
I thought all the RS125 throttle housings were 3 piece, like the early NX5's? They may well be the same unit..
Cable entry is different on the 3-piece housing. Tom runs powerjet cabs, so I believe will need the later cable and housing. I run PJ38's, but still with the later 2-piece housing.
Thu Apr 27, 2017 6:16 pm » Post: #12 » Download Post
You can never stop learning can you, now powerjet carbs, not familiar with them see, just checked, and nf4 and nx4 125's also nf5 250's, all share the same throttle housing, so as you said Mark, later nx5 with p/jet carbs is different, every day's a school day.
MarkR
Thu Apr 27, 2017 7:43 pm » Post: #13 » Download Post
Lesviffer750 wrote:You can never stop learning can you, now powerjet carbs, not familiar with them see, just checked, and nf4 and nx4 125's also nf5 250's, all share the same throttle housing, so as you said Mark, later nx5 with p/jet carbs is different, every day's a school day.
Indeed.. My knowledge of powerjet carbs ends at the throttle grip lol.
Looking at the bikes you're involved with, I'm sure you've forgotten more than I know.
TomB
Sun May 14, 2017 9:00 am » Post: #14 » Download Post
Fyi I've been out with the TZ throttle, and it worked perfectly. Although mine does not have power jet carbs, it's a 97 model. I think they came out in 98/99.
MarkR
Sun May 14, 2017 11:52 am » Post: #15 » Download Post
Glad it all worked out. Did you have a good run? Could have sworn you were on the powerjet carbs - sorry about that..
