MC18 Clutch
tleighbell
MC18 Clutch
Fri Jan 27, 2017 9:42 pm » Post: #1 » Download Post
Looking to replace badly worn clutch, would like to use new parts if possible. The usual sources do not have new clutch hub and centre. I used the part number for the clutch plates to identify other Honda models that might use the same or sufficiently similar clutch. There are several including the 650 Hawk and VT600 cruiser. Latest was a 1989 model. The part numbers for the clutch hub are different, don't know what is actually different about them (number of sprocket teeth, shaft size??).
Any info or help to source good clutch replacement would be appreciated.
