Mc16 fuel tank
Philip laws
Mc16 fuel tank
Mon Dec 12, 2016 9:02 pm » Post: #1 » Download Post
Hi folks. Does anyone know of a different fuel tank to fit an mc16.My tank has the usual rot after 30 years. Can I just warn anyone buying an mc16 to check the tank very carefully before parting with the readies. Most have been standing for years and tanks suffer from rust inside which Finds its way out at the bottom left hand side, and decent tanks seem impossible to find
tim-rsv
mc 16 tank
Tue Dec 13, 2016 3:19 pm » Post: #2 » Download Post
mc 18 doesnt fit,
how bad is yours ? want to sell it ?
Philip laws
Nsr250 mc16 tank
Tue Dec 13, 2016 6:52 pm » Post: #3 » Download Post
Hi,original tank looked reasonable until I poked the minor rusty bits and ended up with a hole about 2 by 1 inches plus numerous other small holes along the bottom edge. On top of that its got sealer in it so not a lot of good
tim-rsv
tank
Wed Dec 14, 2016 8:24 am » Post: #4 » Download Post
same as how mine came from a dealer ......just looking at welding mine , mine also has sealer in it which is a worry because i dont think they treated rust before , have holes on both siddes and 2" underneath
hopefully burn off sealer and remove treat and reseal
cheers tim
07917451666 if you wana message
Philip laws
Nsr250 mc16 tank
Wed Dec 14, 2016 10:40 pm » Post: #5 » Download Post
Makes you wonder if it would be worth someone getting a batch of tanks made in India. Im sure there would be a demand for them seeing how many mc16's seem to be surfacing these days. All 30yrs old and low miles so probably all got dodgy tanks
tim-rsv
Thu Dec 15, 2016 8:25 am » Post: #6 » Download Post
looks like a plan but how do you start it......
tim-rsv
mc18 tank
Fri Dec 16, 2016 7:19 pm » Post: #7 » Download Post
hi phillip
message me on 07917451666 and i can send pictures of mc16 with an mc18 tank on not far off but wolud have to modify mounts
Philip laws
Nsr250 mc16 tank
Fri Dec 23, 2016 8:47 pm » Post: #8 » Download Post
Just seen your message,thanks. I'm just in the process of fitting an mc18 tank. Its slightly longer and the front mounting is totally wrong. Ive cut front mount off an mc16 tank and welded it on to the mc18 tank,movad rear mount on frame back about an inch and fit isnt too bad. Mounts for plastics dont quite line up but not a problem and I might end up with a usable nsr.
