Egt ?
Page 2 of 2  Goto page Previous  1, 2 Download Topic
dodgy
High EGT temps
Tue Feb 12, 2013 9:22 pm » Post: #16 » Download Post
I did a recent trackday and experienced an interesting issue.
At times the EGT was reading up to 1350 deg, but it didn't actually feel lean. The temp rise linear - in that is would keep rising as the throttle setting and RPM increased. I decided to ride another session and just didn't rev it out so far.
I am pulling the head off tonight to have a look, but I do not expect to see any damage.
The question is - is inserting the Koso EGT probe so that the tip is in the middle of the pipe actually too far? The reason that I ask is that a friend tried this setup on his GP bike several years ago and the probe over read temp and also dropped 6hp. Removed the probes and the 6hp reappeared..
thanks
Simon
Neal
Tue Feb 12, 2013 11:25 pm » Post: #17 » Download Post
What fuel are you using ? If the straights were short enough so that it was a brief temperature spike then you are lucky . If you carry on riding like that then it could lead to detonation / seizing etc .
I never did a test to see if I lost power by inserting the probe but I have not noticed anything from test afterwards comparing newer mods .
dodgy
Wed Feb 13, 2013 7:01 pm » Post: #18 » Download Post
Oh, I am using 98ULP as it is a roadbike. It didnt feel lean, and I am usually reasonably able to jet okay with all the years that I raced the RS125. I was keeping an eye on the temp all the time and if if was getting up there, I just eased off the load.
Neal
Thu Feb 14, 2013 6:22 am » Post: #19 » Download Post
Jet up and aim for 1000 with ULP with a long straight . If it climbs slowly on any throttle position it shows that it is lean .
Oil up not seize up !
andyz
EGT - where to buy?
Wed Jul 03, 2013 4:47 pm » Post: #20 » Download Post
Can anyone recommend a place to buy an EGT kit?
Many thanks!
Neal
Fri Jan 03, 2014 11:03 am » Post: #21 » Download Post
The sensor connection
NSR300
Sweet Torquer
Thu Jun 23, 2016 7:03 pm » Post: #22 » Download Post
Hermit
dodgy
Are you guys still active and have your nsr's?
andyz
Fri Jul 08, 2016 9:21 am » Post: #23 » Download Post
Yep! Don't come on here much though.
NSR300 Discussion
