Is that a harris frame or you get someone else to make you a trellis frame? Very interesting. I am sure the frame is more then enough for even an NSR300 power output.
not rode it yet but can't wait to (-; , i built the frame based on half 125 have 250 , to keep weight down and easy handling (i hope) lol , wheel base is 30mm less than a rs250 but same swingarm lenth to keep the front down to some point..
took it for the first ride up the road , videoed it but did not work )-;, got the front wheel lifting in 3thd ha ha ,fun , just made it work .
https://youtu.be/llykuVuMuiY
took it for the first track day last week , apart from a leaky carb at the start the bike run mint all day , when i first built the motor the cluch sliped at 65 hp , fix it piss pooly by a extra washer on the springs but promblem came back , next round hope to race it
its has or a ..
elka honda rs125 rear shock , set to 95kg rider
2010 radial honda rs125 front forks , heaver weight springs
honda gt250 rear wheel
honda rs125 wide front wheel
zx636 front break
ducati rear break
nsr250 mc21 swingarm
fiberglass late model widen tank cover .
home made around 10 letre alum tank
honda 125 bodywork
40mm carbs
hydro formed exhaurst
home made cnc heads with inserts
tyga 300 kit ..barrels and pistons ..etc
15 to 1 compression running on av gas
mc28 dry clutch engine
gpr home built frame
weight 100kg ..95kg if went through bike (-;
ignitech
85hp
https://youtu.be/mJKLgKu6VkU
first race on bike , need to sort some things out , i need to got faster lol , stronger front springs first , lean bike out and make more power , 425 c max on exhaust temp gauge , was told 550-600 c should be the go , think 8hp down , new it was rich but just want to learn to ride it and not work on it (-: , rained for the rest of the day so only got 10 laps in for the day
