I have a pair of barrels removed from a good running R spec engine, these are complete as they came off the motor with heads still on, powervalves in place, piston pins, little ends and the 2 circlips that haven't been removed. Even the base gaskets are still intact so you could were you so inclined fit them as they are. All they need is the other 2 circlips (which I will give you if you ask nicely).
The barrels are both perfect, the bores are in superb condtions, all the cross hatching is visable, no sign of even the slightest contact and the pistons haven't got a mark on them.
I'm quite willing to split them up, clean them and sell them in bits on Ebay (the last barrel I saw went for £167, the last head I saw went for £37) but I thought I'd put them up on here first as a complete top end.
£300 + p&p?
Happy to ship worldwide at cost.
Edit
***sold***
