I'm thinking about using a programmable CDI on my NSR PGM III. I know that there isn't one specifically made for the NSR but it seems if I can:
1. Find a magneto CDI (ie. dirtbike type) based ignition with PV output
2. Replace the coils to match the proper resistance
3. Either mount the new pickup or use an existing pickup
4. Enter the proper curve data and PV data
I should be good to go. Any thoughts?
One other question I have is if I notch my flywheel for the pickup, will this cause a problem with the balance of the flywheel? Any idea how deep and wide the notch will have to be?
rip
