btw
if I were to disconnect the oil pump for a bit and run premix for some shake downs.... what ratio should I run and how many sizes should I go up on the jets. In the carbs right now is 155/152 mains, 40/40 slows, and 72/70 powers. i was running 145/142 mains when the siezure occured though.
should I just blank the power jets out? It is going to be a street bike so i kinda refrained from doing that. so sick of melting pistons.
