MC28
paulc
MC28
Mon Aug 17, 2009 8:02 am » Post: #1 » Download Post
Question from a newbie. How do you tell the difference between an SE and a SP? Frame no MC28 1000541 Havn't found engine no yet. Thanks Paul
RaceFan
1993 Honda NSR250 MC28SP
Mon Aug 17, 2009 8:57 am » Post: #2 » Download Post
SP - Wheels should be magtek units and fork top adjusters should be anodised blue.
If you want a proper 2 stroke get an RGV.
paulc
MC28
Mon Aug 17, 2009 9:56 am » Post: #3 » Download Post
Fork tops anodised blue. wheels Asahi tec. so does that make it an SE? has dry clutch and program card.
RaceFan
Mon Aug 17, 2009 11:37 am » Post: #4 » Download Post
Gold front brake rotor?
My guess given the fork adjusters are blue is that it is an SP.
apexxn
Mon Aug 17, 2009 6:09 pm » Post: #5 » Download Post
Pull the seat and check the model decal on the subframe.
Not much is 100% accurate as far as being a SP but the decal is better than going by the forks or wheels.
watfordhorn
1995 Honda NSR250 MC28
Tue Aug 18, 2009 9:14 am » Post: #6 » Download Post
Can also check the cylinders. SPs have different ones to R or SE models.
Tue Aug 18, 2009 11:52 am » Post: #7 » Download Post
Is that true, are SE and SP cylinders distinguishable?
I've always been under the impression R's came with K marked up barrels and cylinders and SE/SP's came with L marked up ones.
watfordhorn
Tue Aug 18, 2009 12:16 pm » Post: #8 » Download Post
Maybe I am wrong then. I guess any SP "lookalike" will be at least an SE to start with so forget my last comment.
paulc
MC28
Tue Aug 25, 2009 6:25 am » Post: #9 » Download Post
Rotors gold. Sticker under seat states NSR 250R Colour NH 196 Code NH196KB. Wheels red. Is this any help? Regards Paul
apexxn
Tue Aug 25, 2009 6:52 am » Post: #10 » Download Post
It's not a SE or a SP, it's a R.
fstnsr
Tue Aug 25, 2009 7:15 am » Post: #11 » Download Post
Does it have a dry clutch? Does the rear shock have a resivour?
94 mc28 SE
Tue Aug 25, 2009 7:24 am » Post: #12 » Download Post
Does it have adjustable forks with anodised blue twiddly things?
Rear shock adjustable?
Dry clutch?
If yes to above then who cares what it is? It's got the bits you need. The Magtek wheels are an added bonus.
The SP forks (blue twiddly things) have a different design to the SE, where the rebound damping also controls the compression damping to a small amount.
This is definitely one area where all you MC28SP owners can say your bike (or at least bits of it) is better than the MC21 Wink
For all your info, the SE/SP have the same engine. The SE/SP cylinders are marked with an 'L', the R is marked with an 'H'.
paulc
MC28
Tue Aug 25, 2009 8:36 am » Post: #13 » Download Post
Yes to dry clutch,reservoir and blue twiddly bits
Tue Aug 25, 2009 9:07 am » Post: #14 » Download Post
Wel you're sorted then.
Now all you need is a PGMIII. Wink
Case closed
paulc
MC28
Tue Aug 25, 2009 9:30 am » Post: #15 » Download Post
Matt your talking to a complete newbie here.Is a PGMIII a different ignition or what? Regards Paul
