JHA pipes question?
schwarzy930
JHA pipes question?
Tue May 19, 2009 6:46 pm » Post: #1 » Download Post
Hey guy's I got a set of JHA ( i think they are) chambers with the MC21 bike. My question= the left side pipe has a ''threaded-port'' welded on , ( looks factory done) , with a plug. "Pyrometer-tap " I suspect? anyone know? as well as , Why only one side? and not the other? Oh , and the ''port'' is directly straight up and right at mid-chamber., ( fattest-part) of pipe. Also Does anyone have an original set of the matching JHA silencers for sale ,for said pipes? Be kinda cool to get the old originals, is all. thanks ;dave Twisted Evil
RichG
Tue May 19, 2009 6:57 pm » Post: #2 » Download Post
Threaded Port could be for a Lambda Sensor? Used often in 4T exhausts, a 'plug-in' probe can assess mixture strength, fed back to the engine management on-board or externally, via lap-top. Just a guess, don't take this as read!
JHA cans, best bet is to get on OK!Shon / Jahoo Auctions.
Rich
dunkenb
1989 Honda NSR250 MC18
Tue May 19, 2009 9:05 pm » Post: #3 » Download Post
probably a detonation sensor port.
Tue May 19, 2009 10:04 pm » Post: #4 » Download Post
Yeah, it'll be for a Lambda sensor, you can get far simplier ones that just read exhaust gas temp onto an LCD disply on the dash. Different mixtures result in different temperatures.
What you do is determine what the idea mixture/temperature is by running a few plug chops and rejets until the bike runs perfectly, you then know that temp = ideal.
Then at the race you can see instantly if your motor is running optimally.
Why is there only one? Maybe he only had one sensor Idea
scottvor
    Send private message View user's profile Send e-mail AIM Address
Wed May 20, 2009 7:26 pm » Post: #5 » Download Post
Probably for an EGT, exhaust gas temperature sensor. I have them on my pipes. Very handy for tuning.
NSR-lizard
Wed May 20, 2009 8:32 pm » Post: #6 » Download Post
I was under the impression an EGT sensor would be fitted around 150mm from the exhaust port, in the header... not in the belly of the pipe.
Vampire?
Wed May 20, 2009 9:50 pm » Post: #7 » Download Post
Always though that the EGT was a good idea, but couldn't seem to focus on em Scott.....your bike was accelerating that hard! When I did sneek a glance I missed the breaking point for Turn 1 at Willow Springs (or where ever we were) and proper shat myself.
Happy dayz
Wed May 20, 2009 11:37 pm » Post: #8 » Download Post
Yes, well....half decent ones record highest temp since reset.
