NX5 forks question?
schwarzy930
NX5 forks question?
Sat Aug 08, 2009 6:05 pm » Post: #1 » Download Post
Hey guys , I have the 2003-up RS250 NX5 front forks. How much oil ( each tube) and what is the wt. of oil ? For street bike ( NSR/ RS fork conversion) Thanks much ! dave Twisted Evil
geckoracing1
1996 Honda NSR250 MC28
Which model?
Wed Aug 19, 2009 8:38 pm » Post: #2 » Download Post
Hi Dave
I'm pretty sure the NX5 went from 1993-2000, from 2001 on it was the NXA. So your 2003 would be NXa.
If you visit:
http://www.tsrworldwide.com/
and use the parts books on there, you can work out which model bike the forks you have come from.
If you have an NX5 let me know, I have a manual so I can look it up for you. If it's NXA, best bet is to try calling a race bike dealer.
Dan
cgallant
2001 Honda RS250
Wed Aug 19, 2009 8:56 pm » Post: #3 » Download Post
NXA (2001-200X) forks have the following standard service data for them:
Fork Fluid:
Honda Ultra Cushion Oil Special (SAE 5W)
Fork Oil Level:
140 (5.5)/423 cm3 with fork set collar (t=11 mm/0.4 in)
Now I am sure that is extremely helpful Smile
So his is some more details from the manual:
You must use the fork set collar for correct oil level adjustment
Measure the oil level from the top of the outer tube.
Standard Oil Level:
140 mm (5.5 in) with fork set collar (t=11/0.4 in)
Standard Oil Capacity:
423 cm3 (14.3 US oz, 14.9 Imp oz)
Charles Gallant
schwarzy930
Thanks Guys!
Wed Aug 19, 2009 10:30 pm » Post: #4 » Download Post
so if I'm understanding this right , it is 14.3 oz. per fork tube? correct? thanks much!
schwarzy930
RS forks
Wed Aug 19, 2009 10:40 pm » Post: #5 » Download Post
The forks are in fact "NXA1" "L" and "R" as I just looked , sorry for the confusion in my incorrect nomenclature upon my original question. thanks much ; Embarassed dave egan
cgallant
2001 Honda RS250
Thu Aug 20, 2009 12:17 am » Post: #6 » Download Post
Yes, 14.3 US oz of SAW 5W suspension fluid.
of course you should not only put in the recommended fluid level, as well as measure as per mentioned.
Charles Gallant
schwarzy930
forks
Thu Aug 20, 2009 1:09 am » Post: #7 » Download Post
got it thanks!dave Idea
mixalisen
Thu Aug 20, 2009 7:10 am » Post: #8 » Download Post
Dan,
Can you give the NX5 Forks data as i need to rebuild my NX5 Forks and i don't know any specs about it...
Thanks
michael
geckoracing1
NX5
Thu Aug 20, 2009 7:35 am » Post: #9 » Download Post
No problem
SAE 5W
SHOWA SS05 oil or equivalent
136 (5.4) 391cm3 with fork set collar (t 11mm, 0.4 in)
Dan
mixalisen
Thu Aug 20, 2009 8:08 am » Post: #10 » Download Post
Thanks Dan,
Big help...
Michael
