MC18 NO longer for sale
howl
Tue Sep 02, 2008 5:29 pm » Post: #1 » Download Post
A very sad day I must sell my MC18 R2j NSR 250 which I have had for the last 3 years . It has 21000 km / miles on the clock the last 1000 miles have been done with a km/mph converter on the clock. It has got a pair of Jolly moto exhaust pipes which the bike has been set up on the dyno 5/08 making 59.75 hp ( I have the dyno graphs) engine and air box is in standard state of tune. I have up graded the front forks and disks with Honda NC30 ones which have damping and preload adjustment and the disks are larger but keeping the std calipers ( the same type fitted to early fireblades ) and a resprayed mudguard and new mudguard brackets. The suspension was set up by Race Lab for my 13-14 stone frame ( I have the set up sheet ) The engine is in very good order with new rings about 800 miles ago. Also installed are a new set of HD clutch springs. New HEL brake lines and renthal rear sprocket are fitted . The bike is fitted with a very good set of Dunlop Alpha 10s . The body work looks nice but has a few repairs .
A large box of bits are included which include a set of carbs , front master cylinder,powervalve servo, coil. one part of the PGM , rear foot rest hangers, an alu rear sprocket , rear wheel ind sprocket ( requires bearings) 2 barrels with heads ,one is good the other has a repairable crack in the exhaust port and both come with the power valves still fitted , most of a bottom end of an engine inc gearbos ect ( no crank ) plus a lot of other little bits. Also the std pipes ,forks and mud guard. £1900
Horsham West Sussex
