COMPRESSION OFF , and a oil leak
S4
Guest
Wed Oct 27, 2004 5:16 pm » Post: #1 » Download Post
one cylinder is 20lbs less than the other , and the weak one is leaking a bit of oil out of the exhaust manifold. question is can resolve this problem by just replacing the rings one the weak piston, the bike runs fine , i want the easiest solution possible
Thu Oct 28, 2004 6:48 am » Post: #2 » Download Post
Don't we all!
Pour a little oil into the bad cylinder and do the test again. If the compression goes up then you should be okay with just a new set of rings.
Don't forget you'll need a bottom gasket too - leave the head attached to the barrel as it'll save you a head gasket.
Be prepared to do more though if you find the barrel or piston are scored. it would be a real false economy to rebuild with damaged components...
ss4
Guest
same
Thu Oct 28, 2004 4:25 pm » Post: #3 » Download Post
so pour oil into the spark plug hole? like a spoon full. . hope this works , thanks
Fri Oct 29, 2004 6:41 am » Post: #4 » Download Post
Yep.
mark040477
    Send private message View user's profile Send e-mail Visit poster's website Yahoo Messenger
Sat Oct 30, 2004 4:56 pm » Post: #5 » Download Post
Hello!
Can I still get Brand New piston ring, piston pin bearing and cylinder gasket (bottm) for the MC16? How much will it cost?
currency:
1 usd = 56php
thanks!
Mon Nov 01, 2004 7:43 am » Post: #6 » Download Post
I don't know. Only way to tell is to take the part numbers to your local dealer and try. If that fails, try Apexmoto or Tyga.
jeff350lc
Mon Nov 01, 2004 10:05 am » Post: #7 » Download Post
ask matt at tyga. if mc28 pistons fit all nsr,s the rest may also.
