Stock clip ons worth changing?
emerckx53
Mon May 14, 2007 1:48 am » Post: #1 » Download Post
I need to replace the stock right hand clip on that was bunged up years ago. Is there a aftermarket replacement that will work with all of the stockcontrols that is lighter maybe alloy? Or is simply replacing with stock the way to go? Thanks in advance.
'93 MC21 250sp Repsol "Doohan"
rgvsean
Mon May 14, 2007 6:47 am » Post: #2 » Download Post
What is the diameter of the fork? I use Gilles GP Light. The bar is removeable from the clamp but non adjustable set at 6 degrees I think. RRP is around £99 depending which model will fit.
http://www.rgv250.co.uk
http://www.thetuningworks.com
Mon May 14, 2007 8:42 am » Post: #3 » Download Post
NSR leg is 41mm OD
rc46
Mon May 14, 2007 8:52 am » Post: #4 » Download Post
your in the USA right?
Cool then look here
http://www.nsr250.net/forums/viewtopic.php?t=2793&highlight=clip
and then here
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=4598291371&sspagename=STRK%3AMEWN%3AIT
$99 and they where ace, you can adjust the pole to suit! Im sure if you look up the seller he'll have some more, and yes they fit a 21 Very Happy
emerckx53
Mon May 14, 2007 5:25 pm » Post: #5 » Download Post
RC46...Thanks, They should do the trick! Nice work-
Michael
