New noises.
wtf?
New noises.
Fri Mar 23, 2007 1:36 am » Post: #1 » Download Post
Gidday Lads
Have got a '21 with a '28 motor. Just recently the bike has developed a light clicking/clunking noise when pushing it around the shed by hand in neutral. it is louder when rotating the back wheel fwd than in rev. I suspect a noisy gearbox output shaft bearing. Could this be the case do you think? The chain has been tensioned IAW advice elsewhere in this site, although 15mm of slack feels bloody tight to me
If so, is it an easy fix to swap this bearing or does motor come out?
Richard
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Fri Mar 23, 2007 1:43 am » Post: #2 » Download Post
Could be the bearing, but more than likely the front sprocket.
Take a look to see if the teeth are worn or bent over.
If it's the bearing then you need to pull the gearbox out. Don't need to drop the motor.
wtf?
Fri Mar 23, 2007 5:44 am » Post: #3 » Download Post
Thanks for your reply Matt. I only put the motor in 2500km ago and the front cog looked good then, so didnt occur me to suspect that might be it, thanks.
Fri Mar 23, 2007 9:47 pm » Post: #4 » Download Post
If you slacken the chain off, does the noise go away? May be the bearing and the chain is causing the extra tension to create the noise...
wtf?
Sun Mar 25, 2007 12:08 am » Post: #5 » Download Post
Thanks Dave, loosened the chain, noise got quiter/less frequent but didnt disappear.
