lower cylinder problems
fenton
1990 Honda NSR250 MC21
Sun Oct 29, 2006 5:57 pm » Post: #1 » Download Post
my 21 has started only firing on the upper cylinder the lower one is intermittent. done all the regular stuff connecters ect (thanks andy) and it was working fine i parked it up had my tea went back out to go to my mates house and its starting firing on one again i pulled the plug out and its wet with petrol its got good spark and compression and fuel (wet plug) and the electrics are fine any ideas what's up with it ?
j911brick
Mon Oct 30, 2006 5:41 am » Post: #2 » Download Post
Have you put a new plug in?
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
pbekkerh
Mon Oct 30, 2006 8:05 am » Post: #3 » Download Post
Carb float valve leaking ?
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
fenton
Mon Oct 30, 2006 9:33 am » Post: #4 » Download Post
j911brick wrote:Have you put a new plug in?
yes i put a new plug in and it lasted all of 10 miles
Mon Oct 30, 2006 12:05 pm » Post: #5 » Download Post
I really did have the same thing happen on my race '21 a year or so ago. It drove me nuts for a long time. It ended up being a blackened connector inside the PGM 16 pin connector.
I cant remember what colour wire it was now. Look at your lower coil and find the same two wires at the PGM. Take the pgm off and look at the pins for those colour wires. Mine was very black. I cleaned it up with some contact cleaner and all was well again.
fenton
Mon Oct 30, 2006 1:33 pm » Post: #6 » Download Post
i will take it out and have one more look just incase i missed it
fenton
Mon Oct 30, 2006 2:18 pm » Post: #7 » Download Post
when i cleaned it yesterday i cleaned the wrong plug Embarassed Embarassed seems to work ok now but not had chance to ride it cos it pissing down Sad
Mon Oct 30, 2006 2:21 pm » Post: #8 » Download Post
woohoo, fingers crossed hey.
fenton
Mon Oct 30, 2006 2:40 pm » Post: #9 » Download Post
i will let you know later on when the rain stops
j911brick
Mon Oct 30, 2006 3:47 pm » Post: #10 » Download Post
If a plug gets fouled, even once, you you need to replace it. It will never be the same again.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
fenton
Mon Oct 30, 2006 4:49 pm » Post: #11 » Download Post
no good just took it down the road and it stared to do it again Sad i have had the carbs off and striped and cleaned them. all connecters cleaned new plug and still no joy
Jim
Mon Oct 30, 2006 5:55 pm » Post: #12 » Download Post
I had something like this a couple years ago that made me (even more) crazy. It turned out the coil connection (coil blades to wiring harness female connectors) was not as snug as it needed to be. If you've ruled that out, have you also tested the bottom coil itself? Good luck, I feel your pain.
-Jim
'93 MC21
fenton
Mon Oct 30, 2006 5:59 pm » Post: #13 » Download Post
yep ruled that out mate that was the first thing i checked
fenton
Tue Oct 31, 2006 2:03 am » Post: #14 » Download Post
i think i will pull the loom out and give it the once over then in turn all the bits hanging of it as i think its one of those pain in the arse problems that crops up ones in a blue moon. here gos..........................
fenton
Wed Nov 01, 2006 7:52 pm » Post: #15 » Download Post
turned out to be the coil got it sorted now (thanks steve!)
