MC28 temp problem
Juls
MC28 temp problem
Wed Mar 22, 2006 12:16 pm » Post: #1 » Download Post
Is it true that all the MC28 have the high tempurture problem, on the traffic lights and traffic jam i can just feel the heat increasing and temp gauge just go right up to 90 somthing degree. however when i ride my friend's rgv it doesnt seems to have much of this problem.
what is the highest temp i should allow her to go until i switch off ignition?
and in the morning for warming up the bike what tempurature should i have before riding away and should i rev it to warm up?
thanks!
MC28, Repsol
nsrmonkey
Wed Mar 22, 2006 12:33 pm » Post: #2 » Download Post
as long as it doesnt go into the red I would imagine it will be fine, as for warming I beleive 40degs is the agreed ideal temp.
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
Colin NSR
Wed Mar 22, 2006 12:37 pm » Post: #3 » Download Post
I've only had my MC28SP since last August so have no experience of what temperature it will hit at the lights in very warm weather, but I have used it in conditions between 15 - 20 degrees or so and it stays fairly stable at around 60 - 65 degrees. I guess this will vary massively with what's been done to your bike - mine is bog standard except MMax pipes (and a rejet I think). Maybe yours has been tinkered with lots and it is running closer to limits and is kicking out more heat.
I think the warning light comes on (to right of side stand light) if it is over heating. Probably at something like 100 - 105 degrees celsius.
As far as warming up - this was covered in a post recently so might be worth searching for it.
My opinion only - You don't want to start giving it the berries from cold as it won't like it. The temp gauge starts at 35 degrees I think, and I leave it ticking over on choke till the 35 degrees appears, then I close choke and I give it gentle blips of throttle to 3 - 5,000 rpm till it gets to 50 -60 degrees. I will still give it a few miles once moving with only partial throttle and mid-revs to give the engine time to warm through properly. But I have quite a lot of mechanical sympathy - at least till she's ready for some stick Twisted Evil .
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Wed Mar 22, 2006 2:20 pm » Post: #4 » Download Post
I start up my bike, don't let it tick over, blip it up to about 50 degrees then nail the beeaatch.
I've no mechanical sympathy whatsoever.
A bit like Luke's gear change club foot really
Wed Mar 22, 2006 2:32 pm » Post: #5 » Download Post
Juls wrote:MC28
nsrmonkey wrote:as long as it doesnt go into the red I would imagine it will be fine
hmmmm.............
Mine has run well past 100*c before in traffic, but it has also seized twice Rolling Eyes
Clarkie
Wed Mar 22, 2006 2:42 pm » Post: #6 » Download Post
Bleedin Philistines again! Shocked
Warm it up to 45deg+ before setting off.
Give it the beans at 65Deg.
Mine goes to 100 in traffic - worry not - provided it comes back down.
Water wetter improved things by 3-5degrees all round.
Max will sort this out properly if it REALLY bugs you! Very Happy
Your call.
Image Hosted by ImageShack.us
maxim
Wed Mar 22, 2006 3:43 pm » Post: #7 » Download Post
Oh yeaaah... Just fit a bath tub sized radiator and let the thermostat do all the work... Laughing
