speed restriction
2-stroke johnny
speed restriction
Wed Dec 14, 2005 6:42 pm » Post: #1 » Download Post
anyone know how the mc16 is restricted? is it speedo or a black box? cheers.
it's a name, not a condition
rsvr1000dan
Wed Dec 14, 2005 7:23 pm » Post: #2 » Download Post
I think you'll find it is restricted on the black box. I believe it is a simple one to do. Have you tried looking at the tuning section on this site??
I'm sure plenty of people Dave / Andy or Matt will be able to tell you.
Good luck.
Wed Dec 14, 2005 10:18 pm » Post: #3 » Download Post
I don't believe the '16's were "restricted" at all, speed restriction wasn't law then, tiny carbs and weeny ports are the reason they've only got 45bhp.
I can't find anything in the tuning section about them, probably as the only thing to do is replace the offending barrels and carbs with later bits, alledgedly the '18 and '21 pipes sort of fit too.
2-stroke johnny
Thu Dec 15, 2005 12:33 pm » Post: #4 » Download Post
I assume 18 and 21 barrels and carbs bolt straight on the 16 crankcase? anyone done this before?
mat grant
Thu Dec 15, 2005 5:11 pm » Post: #5 » Download Post
Hi,
I have fitted MC18 barrels to an MC16, the barrels went straight on. (I got a cheap engine on ebay that said MC16 on the item, but it turned out to be an MC18. The carbs go on but you need the MC18 rubber as well as the carbs. The airbox side of it goes straight on.
I'm about to try fitting MC18 pipes to see if I get a power boost, if I can get them to fit.
Mat.
